DJI Susan
Hi there, could you please double confirm that if it is only the record button does not work? Please refer to the setup method below and make sure that the camera has been connected correctly. Please keep us updated if the issue persists.
Multi-Camera Control Cable (Sony Multi)
1. To ensure the gimbal can detect the camera successfully once the camera control cable is connected, power on the gimbal before the camera.
2. The optical zoom can be controlled if the lens used supports Power Zoom. Otherwise, only digital zoom can be controlled. The setup process is as follows: Select Menu, Settings, Zoom Settings, and Digital Zoom.
3. After connecting using a Sony multi-camera control cable, it is necessary to restart the gimbal before swapping to another cable.
4. When using HDMI (such as connecting to a monitor or Ronin Image Transmitter), only the monitor will show images during a playback; the camera screen will not show any images. |
