Battery Grip Defective Screw Port
6871 12 2018-12-10
Tokidoe
After a recent shoot I was unscrewing my ronin S tripod from the battery grip. A couple twists and I realize it was rather difficult (almost seemed jammed) as I was trying to loosen it. I figured maybe the threads were mismatched upon unscrewing it.
After turning tightening and loosening it just a little the inner thread wiring of the battery grip was found stuck on the tripod piece upon taking it out.
Now I’m left with a damaged thread on the battery grip and a damaged tripod .
What could I do at this point ? Would I be able to get a replacement/repair ?
2018-12-10
Hi Tokidoe, we're sorry to read your post. Please kindly start a case and send it in for diagnosis: https://www.dji.com/support Please kindly provide us with the SN and case number once you got it, we'll keep following up, thank you!
2018-12-11
arthurbikemad
Flight distance : 49954 ft
Thats the Helicoil, its an insert used to repair or create a durable thread in soft alloy, if they are fitted without a thread locking liquid they can often come undone as that one has, its far from unrepairable and is unfortunate that its become loose and has unscrewed its self from the Ronin S grip, personally I hate the things, a Wurth Timesert is a much better option IMO but many manufactures use Helicoils just as DJI have.
Any good engineering shop should keep them (but most will prob keep metric sizes), they are fitted with a tool that locks onto that TAB inside the one shown in your image, that TAB is sometimes half cut so it snaps off once tight leaving a thread that is clear all the way though for a bolt to pass. Me, I'd send it back and suggest DJI perhaps use a better method to give a durable thread in soft aluminium.
By the way, I've fitted hundreds of them in my time with Motorcycles.
2018-12-11
StianGel
Flight distance : 686654 ft
Check you're area for machining shops. They may be able to help you with mounting a new helicoil. You can also find 1/4 unc helicoil kits on ebay.
2018-12-11
Tokidoe
arthurbikemad Posted at 12-11 01:06
Thank you so much for the advice . I’ll take a look around Some machining shops to see how much it’d run me .
Although , I may send it back to support after all due to the damage to the tripod piece .
Thanks again for the helpful advice .
Cheers !
2018-12-12
Tokidoe
StianGel Posted at 12-11 01:13
Thank you very much if I decide to go with the machining shop I’ll make sure to look over on EBay for the coils .
Cheers !
2018-12-12
AVA_
This has just happened to me!
How did you end up going about fixing this?
2019-11-20
fansd31e8ac6
Puerto Rico
Just bought mine in June and I have used it 7-9 times and this already happenedi bought the extended grip thinking's it was a tripod/grip problem , I have not yet come to find a solution I'm very sad about this since its new and I can't use the support because it does not register mi zip code.
2020-9-13
Ramonchous
Puerto Rico
DJI Susan Posted at 2018-12-11 00:09
Can you help me?
2020-9-13
I am sorry for the issue, Ramonchous. Please send the unit back to us for further assistance. Please contact our support at http://www.dji.com/support to start a case. Thank you.
2020-9-14
myse1f
DJI Susan Posted at 2020-9-14 01:55
Very sad to read this, and also see the pictures above as I experienced this same issue and recently sent my BRAND NEW battery grip into DJI and hey quoted me $99 to replace!!! INSANE!
Highly disappointed in the level of service I'm getting from this.
Here's my case # CAS-5244833-Q9W2T1
I just dealt with this SAME exact issue last week with you guys, and you quoted me $99.. shameful.
2021-5-7
myse1f Posted at 5-7 18:48
Hi, I am sorry for any inconvenience caused.
I had checked the case details, as per the serial number, the Ronin S was activated on 15 Dec of 2019, it is beyond the warranty period, and as per damage assessment, physical damage was made. Thus, the case is not covered under warranty.
Please let me know if there is any misunderstanding, thank you.
2021-5-9
djiuser_fGXYawZlxl3e
Flight distance : 194501 ft
My Rs 3 mini just broke as well.
Opened a case since I have warranty but wonder if they would still try yo charge me. This is definitely a bad design and poor judgment on material used..
This is all plastic and should have at least 2 mounting screws for better support.
My Fx30 set up fell once this broke!!
This gimbals should be better materials
5-7 18:11
