FW release v01.04.08.01 Gray
3213 39 5-7 08:32
Fishycomics
v01.04.08.01 Gray is being released  what just noted only FPV  upgraded of some sort,  so tell  me what else is new with the May 2024 releasing
Lets see 1. Added Support for 4K for UVC and 25/30fps output
2. Active track and recording with DJI mic 2 with Livestream
3. Added FPV+ gimbal mode
4. Added option for Auto Power Off, never is Now
5. Adjusted the order of  the wearable ..
6. Optimized the Auto Foucs Proformance
and Bugs and issues
No mention of Reducing the prompting of the DJIM2
So I will stand By and wait  and see if its worth the DL .  I have the auto-focus hunting so that would be my reason to DL can not wait and hear what we Like/Dislike
great job DeJing official stickie  of release topic
here
here
5-7 08:32
iShaggyi
not updated, live streaming mode does not work until updated
5-7 12:26
RanoV
This breaks RTMP livestreaming mode. Only audio seems to be coming through.
5-7 12:54
Marlow
Flight distance : 38442 ft
Confirmed: firmware update breaks RTMP streaming indeed.
0 Kb/s video, audio is streamed.
Factory reset did not remedy this.
/M
5-7 13:14
hfuentes73
Flight distance : 108730 ft
Live streaming does not work, it stops after 17 secs
5-7 16:07
playok
South Korea
I received a firmware upgrade notification and after updating, the RTMP streaming is not working.
When can I expect to receive a fix version?
5-7 16:56
MrPb
South Korea
Live streaming does not work after firmware update.
Is there any way to downgrade?
I hope dji will check this issue  and quickly hotfix or rollback.
5-7 17:02
Kim Blog
South Korea
After the latest update to Osmo Pocket 3 FW Release v01.04.08.01, real-time RTMP live does not work properly.
A fix patch or rollback update is required.
5-7 17:51
fans4ac61046
South Korea
When streaming after updating the firmware, only a black screen appears. Please fix it quickly
5-7 19:07
DJI-ytao
DJI R&D Squad
Flight distance : 1209413 ft
thanks for the feedback, we are looking into this issue.
1. what live social network has the rtmp issue? facebook, youtube or anything else ?
2. setup the live via iphone or anroid phone?
5-7 22:24
Hi,there.We need to confirm the information with you:
1. What platform do you use for RTMP live broadcast? We have tested that YouTube and Facebook can live broadcast normally;
2. Provide MIMO configuration interface screenshots or process screen recordings.( You may save it through a shareable link like Google Drive and DropBox, then send the link here.)
3. Is it possible to broadcast live before upgrading the firmware?
5-7 23:12
Aavis
Flight distance : 328 ft
Finland
I just cant believe it that you still cant tilt using joystick up/down while panning with hand in Tilt Lock mode... It still locks the facing of the gimbal... With all other gimbals it works.
5-7 23:29
Kim Blog
South Korea
DJI Susan 게시 시간: 5-7 23:12
안녕하세요. 정보를 확인해야 합니다.
1. RTMP 라이브 방송에 어떤 플랫폼을 사용합니까? YouTube와 Facebook이 정상적으로 생방송을 할 수 있는지 테스트했습니다.
2. MIMO 구성 인터페이스 스크린샷 또는 프로세스 화면 녹화를 제공합니다.(Google Drive 및 DropBox와 같은 공유 가능한 링크를 통해 저장한 후 여기로 링크를 보낼 수 있습니다.)
I used both methods: sending the RTMP address directly to OBS or using it with a smartphone (iPhone).
If you broadcasted normally as RTMP in the previous firmware, after this latest update
There is a symptom that RTMP broadcasting does not proceed normally.
5-7 23:47
What actually is FPV+ gimbal mode
5-7 23:52
fans4ac61046
South Korea
DJI Susan Posted at 5-7 23:12
A. Send RTMP to OBS.
2. Provide MIMO configuration interface screenshots or process screen recordingsa( You may save it through a shareable link like Google Drive and DropBox, then send the link here.)
A. maybe settings like this : http__s://youtu.be/adUzAr1j2x8?si=9WNFfDpinywLfvRG
now stream here : http__s://chzzk.naver.com/live/65c3035bdc598c81f15a8fe0e958b3ce
A. Before the firmware update, broadcasting was possible smoothly.
Is there at least a way to roll back to the previous firmware version?
5-7 23:55
fans4ac61046 Posted at 5-7 23:55
Hello, thank you for your reply.Could you please provide a video showing the issue? You may save it through a shareable link like Google Drive and DropBox, then send the link here. We will check this further for you.
5-8 00:03
Aavis
Finland
DAFlys Posted at 5-7 23:52
P3 FPV+ is actually the same like P1 / P2 FPV mode. It works now similar.
But gimbal orientation lock while tilting while panning problem is still there in Tilt Lock mode..
5-8 00:22
Aavis Posted at 5-8 00:22
Is that like torch mode?
5-8 00:23
Kim Blog
South Korea
After going live in the app, it behaves the same as before, but
The timeline progresses after the live start, but is displayed in black on a separate broadcast screen.
It will be forced to stop within 10 to 15 seconds.
5-8 00:49
Marlow
DJI-ytao Posted at 5-7 22:24
Generic RTMP to a regular RTMP ingest is the issue. I've not tested the social network implementations.
Setup doesn't matter. Both Android and iPhone. The issue is the camera, not the setup.
/M
5-8 04:23
Marlow
DJI Susan Posted at 5-8 00:03
Honestly, you should have test units in your team.
Set up a RTMP live stream via the Mimo app (doesn't matter, if Android or iPhone), look at the resulting stream .. you'll find ... it's black.
Looking at the statistics of for example a NGINX with RTMP plugin proxy, the camera is only sending audio, but no video at all.
And yes, this was fully working before the firmware update.
Requesting videos on issues that are this simple to replicate is over the top. This should have been tested by your team before releasing the firmware in the first place.
Here are the relevant screenshots:
https://www.flickr.com/gp/44651774@N05/1zK7987nxc
https://www.flickr.com/gp/44651774@N05/i8gr1rVMs0
https://www.flickr.com/gp/44651774@N05/5F1TuA27X6
https://www.flickr.com/gp/44651774@N05/7YmFJeL827
As you can see in the last 2, 0 Kb/s for video, 341 Kb/s for audio. The video feed is not being transmitted.
/M
5-8 04:26
DJI-Osmo-User-1
Looks like its been pulled already.
5-8 07:50
IRL-Fan
<post removed, error while posting>
5-8 08:39
Fishycomics
Pulled, why never rush to Download firmware that is betaware, DJI should now offer the previous firmware on the Mimo App sp np one  is stuck with damged goods
Glad DJI  revised  the firmware off the site
5-8 08:40
IRL-Fan
Oh no, I've missed the firmware upgrade...
Would have loved the new webcam UVC mode.
I don't need RTMP anyway.
5-8 08:45
Fishycomics
they will release it soon a simple fix, for sure.
5-8 08:53
Aavis
Finland
Was it beta? I just opened mimo today and it said new firmware and I installed it. didnt know it was bad timing.
5-8 09:26
Fishycomics
Aavis Posted at 5-8 09:26
5-8 10:24
Fishycomics
read that as if it works it will be  official anything they do as a prerelease is beta called Gray IMHO
5-8 10:24
Aavis
Finland
Fishycomics Posted at 5-8 10:24
Didnt know that thanks!
5-8 11:41
Aavis
Finland
I dont have any gray options in mimo in about or any other place there. But it seems it still got it.
5-8 11:43
Fishycomics
Since DJI pulled hte Firmware and  if they reload then we know what to expect, but if they repaired and fixed  itt hen we'll see a different fw version  on the Mimo as well stickied  here   and htat should be a week or so I bet  hope they resolved the concerns and promised to take care of the prompts I will not hold my breath on it
oh look the loser got a nother DV in   quick quick
5-8 14:56
DJI-ytao
DJI R&D Squad
thanks for the feedback and we are working on a fix on this.
5-8 18:43
Aavis
Finland
Is it safe to use the device for normal filming with Gray firmware? Since cannot downgrade it.
5-8 23:11
Fishycomics
If DJI wants to go through the App to send you a Downgrade, they can,.  As mistakes are made,  they are fixing it they did say in a few days they would have released it and imagine the complaints then?
5-9 02:56
Aavis
Finland
Fishycomics Posted at 5-9 02:56
Good thinking. Just filming kids nothing stream things.
5-9 06:57
RanoV
Hi DJI Team,
Is it already clear when a fix for the RTMP issue is being released?
5-10 07:46
Hi guys, we are sorry for the inconvenience caused. The latest firmware version has resolved this issue. Please update to the latest version. If there is any issues, please feel free to contact us.
5-11 05:20
Fishycomics
Opening the mimo App New firmware loaded
can not DL fw till usb type C i unplugged and same exact notes    so this is now called FW V01.04.802
5-11 05:34
DJI-ytao
DJI R&D Squad
Hi, Firmware V01.04.0802 fixed this livestreaming issue.
5-12 18:20
