Manual Mode
1859 17 4-20 04:36
AvroTrain
Flight distance : 1375318 ft
Hello All. New to FPV and had my first flight with the NEW Avata 2 another addiction!. Wondering how to get it into Manual mode? (I know practice on sim first LOL ) I only have the RC Motion 3 but thinking getttng the RC. All you tubes they are using the controller 3 to get into M Mode.
4-20 04:36
JeremyB31
Flight distance : 1364560 ft
They say manual mode can only be enabled with the FPV controller 3.  There is a video on manual mode https://www.dji.com/avata-2/video
4-20 05:51
AvroTrain
JeremyB31 Posted at 4-20 05:51
Coincidence I just read another forum Would have been nice to know that prior. Thanks
With motion controller you cannot active the manual mode, manual mode only can be use when you are using Remote Control 3.
Just spoke to DJI Tech support and they'll send feedback to Engineering hopfully for an update. Feeling I get is manual mode flying needs more precise movement. I'll prob be forced to spend $200 more.
4-20 05:57
Hi there. Thank you for reaching out. Before the first flight of DJI Avata 2 in Manual mode, perform the following operations:
1. Power on DJI Avata 2, DJI Goggles 3, and DJI FPV Remote Controller 3, and complete linking.
2. In the goggles view, go to Settings > Control > Remote Controller and set Custom Mode to Manual Mode.
3. Open the protection cover behind the throttle stick and adjust the screw until the throttle stick does not re-center automatically for more accurate control and a better flight experience.
4. Switch to the Manual mode for your flight.
Pay attention to the following items:
1. The Manual mode is a fully manual control mode. Compared with the Normal mode and Sport mode, this mode presents greater control complexity. In Manual mode, the drone does not hover automatically. Please practice thoroughly on the simulator before operating your drone in Manual mode.
2. While operating the drone, it is advisable to avoid performing sideways maneuvers or U-turns at high speeds, such as sharp lateral drifts or rapid turns on windy days. If the flight altitude exceeds 5 m, in the case of a drone attitude anomaly, DJI Avata 2 will trigger an emergency brake.
3. When using Manual mode for the first time, the maximum attitude of the aircraft will be limited. After you are familiar with flying in Manual mode, the attitude restriction can be disabled in the goggles: Go to Settings > Control > Remote Controller > Gain & Expo > M Mode Attitude Limit.
4-20 22:08
mkheng.kurnia
Flight distance : 10251168 ft
Might be a daft question but are the speeds in full manual and attitude restricted manual both the same?
5-3 09:44
A J
Flight distance : 14588274 ft
This YT video shows the reality of using manual mode for the first time with little sim practice.
5-3 10:03
djiuser_t7F74EZIqY28
Flight distance : 112641 ft
A J Posted at 5-3 10:03
https://www.youtube.com/watch?v=EqrjG-ZH6FI
Hey thanks for sharing my video! ☺️ I May have had very little sim practice but I took the leap and I did what people who I know do the sim, but never leap to real life! Now I'm flying without crashing and soon I'll be confident to try more flips. I'm proud of myself for giving it a shot and I hope others will make the leap too, because once you start getting it, you don't want to fly any other way! Thank you again! JJDrones
5-5 19:37
A J
djiuser_t7F74EZIqY28 Posted at 5-5 19:37
Nothing wrong with taking the leap - I've used your video as an example of what flying in manual is actually like in real life to someone who is thinking of doing it. So many youtubers fly around in manual and make it look so easy and awesome as they've done it for years with countless hours of practice that people often think they can replicate it after a few flights only to be very disappointed or worse, lose their drone.
Your crashing the drone 8 times in two flights when flying in manual for the first time brings a reality check for others to see and hopefully learn from. Not to dissuade manual flying but to highlight the need of preparation or, as in your case, just get on with it and take your chances but being aware of what may happen.
Glad you are not crashing anymore and getting the hang of it.
Silver Fox...
5-6 01:20
A J Posted at 5-6 01:20
Thank you very much my friend and as always very well said!
5-6 07:50
A J
djiuser_t7F74EZIqY28 Posted at 5-6 07:50
And thank you JJ. Keep up the great content - we are all learning in our own way mate!
5-6 08:11
AvroTrain
So far I am enjoying FPV immensely. Getting more confident in Manual mode. Still some ground to cover.(See what I did there? LOL)  Not sure if thee is a definite answer for this question. What is the difference in angle when diving in Sport mode vs. diving in Full unrestricted Manual mode? Cause Sport mode diving isn't bad. Occasionally I see the front of the craft in the shots when full fwd diving.
5-12 04:33
A J
AvroTrain Posted at 5-12 04:33
Not sure of precise degree angles but in full manual there is no restriction at all as you can do 360 degree flips and spins. I would say sport is restricted at best to -80 degrees. Further more sport mode is restricted to around 35.8mph whereas full manual can exceed 60mph so the dive will be much faster and the pitch curve coming back up in altitude will be more fluid (subject to not crashing as 400' to zero feet at 60mph gives you a window of 4.5 seconds)
5-12 04:56
fichek
Flight distance : 1036263 ft
Croatia
In manual mode you can literally point the props directly at the ground if you wanted to (not that you would). Ideally you'd dive at about 110-120 degrees and could smoothly go into a free fall even without any throttle. With sport mode you're limited to 9m/s descent speed (and that's when you either point the RCM3 straight down towards the circled down arrow, or just hold throttle stick all the way down on FPVRC3) and Avata is really shaky when it goes down.
5-12 05:45
AvroTrain
fichek Posted at 5-12 05:45
Finally today I removed the Manual restriction and was a bit nervous but I"m passed that now and the addiction is getting worse! LOL
5-19 16:57
A J
AvroTrain Posted at 5-19 16:57
Or better as it means you are progressing. I'm in the same boat as you.
5-20 00:42
AvroTrain
A J Posted at 5-20 00:42
here are some things I'd like to see in an update for the Avata2.
1, An option that keeps the gimble stays pointed at the horizon in manual mode so one doesn't have to adjust it.
2. an low level sensor ground lock like 1 to 1.5 ft above the ground option for proximity flying
5-20 03:34
A J
AvroTrain Posted at 5-20 03:34
The purpose of manual is just that - all the help is turned off. If you want straight and level horizons in your footage then switch on horizonsteady.
The VPS on the Avata 2 is one of the best out there - it's hard to crash into the ground but there is no harm in asking.
5-20 07:42
OldGuy2024
Flight distance : 577543 ft
My normal transition from angle to manual mode on non-DJI quads is first set rate profile to the most mellow programed.  Then to fly LOS with or without a LED monitor to get a feel and perspective of the quad.
Even then take offs and landing on the pad are usually a challenging moment.  Even hovering, "walking the dog", flying a level square flight pattern are all "interesting".  The questions is: can you just insert a lens cover into the Goggles 3 and fly LOS?  Don't yet own a RC3.  Hope is DJI will make the RC2(?), the tx with the led screen back compatible with the A2.
5-21 11:09
