Mobile device CPU fully loaded. Related performance will be affected.
2146012299 2146012299 2017-6-17
fans420fe723
Flight distance : 5225404 ft
I am getting this message "Mobile device CPU fully loaded. Related performance will be affected. I started receiving this message yesterday. I I have had my I2 for about five days now. I have the latest firmware and have the Dji go4 App on my tablet. I have an IPad mini 3. Could anyone advise on this message. Thanks
2017-6-17
Cougar1
Flight distance : 939580 ft
Probably telling you that the iPad 3 (same as iPad2) is not able to cope with the load. Upgrade device to at least a Mini4 if you like to stay with the small iPad.
2017-6-17
DJI-Jamie
Flight distance : 112405 ft
For the sake of troubleshooting, have you tried a different mobile device? Do you have video caching enabled or disabled? Does that iPad have as much memory available as possible?
2017-6-17
RichJ53
Flight distance : 1837356 ft
Hi
Like cougar said, it sounds like you need more power
I am running the iPad mini 4 128 gig memory and Wi-Fi / cellular version. No issues with any of my DJI drone including the I2
Rich
2017-6-17
Mark Guille
Flight distance : 2290220 ft
Jersey
DJI-Jamie Posted at 2017-6-17 21:30
Hi Jamie,
Would video caching make much difference? I may try this next time I get issues.
Mark G.
2017-6-18
fans420fe723
Thank you, really appreciate your time and input.
2017-6-18
fans9f6601d1
Egypt
I get the same message while flying using iPad mini 2. This problem just started happening 2 days ago right after I updated the firmware to the latest version. The iPad has more than 30 gigs of free space and is up to date. When I switched to using my iPhone 7, it worked perfectly and this message never appeared.
2017-6-19
Cougar1
fans9f6601d1 Posted at 2017-6-19 07:38
Sorry mate, the fact that you have free storage space on the iPad does not make it any more powerful.
The Go4 in conjunction with the Inspire 2 needs more power to run smoothly, Mini 2 & 3 is not a good fit for the I2, need an Mini 4 or better to be smooth.
2017-6-19
fans21d4f89a
Same thing to me. I got P4P and Ipad mini 2 about 4 months. Everything was fine before, then suddenly happened yesterday. The video is lost even 20 feet away.
2017-6-19
DJI-Jamie
Mark Guille Posted at 2017-6-18 03:02
Hi Jamie,
Having the Video Cache enabled does takes CPU power that can be taxing on some mobile devices more so than others. If you're noticing some lag or overall performance issues with the app itself, running things at the bare minimum can help alleviate the issue.
2017-6-19
DJI-Jamie
fans420fe723 Posted at 2017-6-18 05:55
You're welcome, please let us know if you noticed any changes when you have the chance.
2017-6-19
ronin rs211
I got the same message after I did the latest update with my iPad mini..
I never had it with my phantom 4 or the Inspire 2 until the update...
Maybe DJI should just stop messing up the Inspire 2 for a change.... Software when done right the first time does not need to be upgraded.
2017-6-19
Seachronicity
Flight distance : 852792 ft
I have the same issue as well.  I2 latest update, iPad mini4 128GB.  This began after the last update.  Tried restarting program,  on my Ipad stopped updating apps in the background and stopped cached videos in Go4.  Stopped the other programs from running in the background.
This must be a bug.
Hope DJI-Jamie is watching this.  Never had a problem before with over 80 flights.
2017-6-19
JMatic
Croatia
Same thing. Phantom 4 pro + ipad mini 4
Video signal keep braking and that warning message keeps poping.
I have big shooting tomorow and it is anoying as hell.
2017-6-19
raven4
Flight distance : 86194 ft
Same here, ipad Mini4, 128Gb. never had this problem, before. Just got that warning on Go4. It's gotta be a bug.
2017-6-19
Cougar1
raven4 Posted at 2017-6-19 11:34
Well I understand it could happen on an Pad Mini 2 or 3, but if it also happens on a Mini4 something is up. Will test on Wednesday with my iPad Pro.
2017-6-19
xefudo
Flight distance : 7857828 ft
Portugal
Its true, after app update, I have same issue with two different mini 4. I think that is bug app. I have 80 flights before the update and never happen. after update happen all the time. I reinstall app and have two flights and never happen. I am wanting for more opinions.
2017-6-19
DTK
Flight distance : 1943159 ft
I am calling DJI to move their app to full fledged PC/Mac tablet. Their apps are getting out of control requiring so much resources.
2017-6-19
raven4
DTK Posted at 2017-6-19 14:29
I'm noticing that there's a TON of applications still open on my iPAD mini4, even after a complete power down and restart.  I just did a FORCE CLOSE on about 30 apps still running in the background. Just closing the app with the sleep button or powering down, doesn't seem to terminate these apps. I'm wondering if this is part of the problem with this error message.
2017-6-20
Cougar1
raven4 Posted at 2017-6-20 07:07
I think you have the reason right there, people need to close apps running in the background. Easy to do just double-tap the home button and the "swipe up" on any unwanted apps to close them.
Was out testing today and had NO issues at all, running booth latest Goapp4 and updated RC firmware.
2017-6-21
JUAN P4P
Colombia
I think most people is aware on how to close their ios apps! in my case im on an iphone 6 p4p dji go4 and my iphone 6 has plenty of memory, 40% free, what its going on dji?  seems it has something to do with thedji hdmi module on my case because after taking it off and putting back the original usb-only module, i never get that message
2017-6-21
Skyggen
Flight distance : 321168 ft
Turkey
I had same issue 1 hour ago. Mavic Pro and IPad mini 4
2017-6-22
Skyggen
Turkey
Also I dont find (Enable hardware decoding) anymore in the Dji go 4 app
2017-6-22
ronin rs211
I get the feeling DJI are forcing us all to buy the Crystal Sky monitor since they forced us to install the crap updated app on our once perfect I pads....
2017-6-22
ronin rs211
So far the only slightly better fix is to resort to the March firmware using the DJI assistant and it still isn't as good as the drone was back in February ... The POV camera is much faster  than the X5s video but the screen is just too damn small for a professional setup.
2017-6-22
Cougar1
Skyggen Posted at 2017-6-22 03:33
You seems to be right, "Enable Hardware decoding" is no longer available in new app (4.1.2) that would make a huge difference and could be the reason.
Well spotted!
Edit: the option is now automactically on as per DJI. "CPU overload" has been reported.
2017-6-22
fans1e7bea63
Flight distance : 396227 ft
Same problem here, Phantom 4, iPad Mini 4. Talked to DJI support today about, was not really knowledgable about the problem, suggested I downgrade firmware and try it again. The only other possibility was the hot temperature when flying, but unlikely. I had the degraded video link, breaks, and green screen as well.
2017-6-22
ProBowie
Flight distance : 1096198 ft
I too am having this problem.  Inspire 2, iPad mini 2 perfect workflow and never a problem.  After updating, I kept getting the message... I love the iPad mini size but feel like I must now upgrade to an iPad Pro.  Anyone with a iPad Pro have this problem??
2017-6-23
Hi guys, I have feedbacked this issue to our engineer, just to clarify, the DJI Go 4 you installed are all latest version V4.1.2, right? And what's your iOS version? Does Android device has this problem? Anyone had tried Android?
2017-6-23
Aeromirage
Flight distance : 1778045 ft
I have already accepted the fact that technology moves on and my iPad mini's days are numbered. So I have a Crystal sky on order.
[Also sick and tired of having to use hoods to be able to see monitor!!]
Meanwhile, while I await it's arrival, I have set image transmission to 720p and  disabled video caching .
Flew yesterday and got no warnings.
2017-6-23
ronin rs211
Aeromirage Posted at 2017-6-23 06:26
and how was the latency between what the X5s and iPad or even that between the X5s and the crapy POV camera...
2017-6-23
Cougar1
DJI Mindy Posted at 2017-6-23 04:46
I have an iPad pro and running latest fw and app 4.1.2 (IOS) on my I2.
Did some testing today and can reproduce the issue but ONLY in 5.8ghz and far away from RC. No issues on 2.4.
So maybe users also should check what wifi (if they use booth) the are on as well as any issues with lot's on network, low altitude, obstructions etc? Not saying there is not an issue since I did see it, but it was only on 5.8. Also note, my iPad is way more capable then an Mini.
2017-6-23
LW_GEO
Flight distance : 1207431 ft
I have the same problem. Last update I2, iPad mini4 128 GB.Many flights and this message has never been made.
The Ipad mini 4 is a rarely used app.
100 GB free memory
2017-6-24
SerSigal
Flight distance : 369652 ft
I have an i2 with ipad 2 mini and has always worked well ... before the latest GO4 and hardware firmwares upgrade. Now I have this issue.
Technically, my contribution to identifying the problem is as follows: after the upgrade of the latest firmware (aircraft + RC) and the GO4 app I flew fine, with a climate of 25-30°C, until June 20th. On June 22th I moved to warmer latitudes (33-38°C) and since then I have the problem.
Politically, I think it is not right to exclude, at least without notice, a previously compliant tablet model. If DJI felt it was necessary to exclude tablet models would have signaled it with a warning at upgrade time. Right DJI?
I think DJI should revieu the software immediately.
Now I'm trying to figure out whether I can downgrade GO4 app. Any advice?
2017-6-24
raven4
DJI-Mindy....My iPad 4 mini  is on the latest iOS, v10.3.2
2017-6-24
Seachronicity
DJI, please fix this.
Across the web, people are experiencing this not only with the I2, but with all of your models. Description of the problem extends across multiple languages.
This has occurred only since the latest Go 4 update.
It occurs on IPads and IPhones including the Mini 4 and the IPad Pro including the 128gb models. It occurs when no other programs are loaded in the background.
My CPU is definitely overloaded, and for the first time, I am getting video glitches with SSD prores.
I cannot reliably use the I2 for fear of recording bad video.
Again, this did not occur with the prior DJI Go 4 version.
Your help is appreciated.
2017-6-24
Skyggen
Turkey
All my gear is on latest firmware. Did more testing yesterday. After I mounted a sunscreen, I had no issues with 3 full batteries. Will test again tommorow with and without hood.
2017-6-24
fansdceb5c97
Flight distance : 2640577 ft
Yep, same issue. I2 / iPad Mini 2. No problems until the latest Go4. Clearly in software. Did a pro shoot last week and the camera op's feed (he was using the Mini on the cam sticks) kept lagging with the "CPU overload" warning appearing. I was using my iPhone 6Plus and seeing the lag as well. Never had this issue in the least until now.
Ordered the Crystal Sky 7.85" Ultra Brightness, which they are saying now won't even be shipping until the END of July. Really frustrating and not a good look for my company and DJI if it's failing on gigs with pros.
I was thinking about grabbing an iPad pro in the meantime...but according to what I'm seeing here....iPad Pro wont be a fix for this?
2017-6-24
Cougar1
fansdceb5c97 Posted at 2017-6-24 07:22
If it helps, I can tell you my iPad Pro 10.5" has no issues at all, plenty of power.
DJI still needs to fix this, why was the option to turn on/off the "enable Hardware decoding" removed in IOS? Like to have it back, even if DJI enables this behind the scenes (as some DJI rep. told me) , I like to know it is on, clearly something is wrong.
2017-6-24
Tomnrenee
Flight distance : 337536 ft
Just got samething for first time. CPU FULLY LOADED.
No changes ipad4 phantom 4 pro. 6 months no problem. Only change was updates. Hope this is a quick fix.
2017-6-24
