Hi, I have a Mavic Air. After the last flight, all was good, and I did not use it for several months. Yesterday, I tried to flight and the DJI app asks me to do IMU calibration which gives me CODE ERROR 13 after long minutes of wait. I tried IMU calibration in a low-temperature room, outside, inside. I really don't know what to do.
Hello there rdias29. I am sorry for the trouble this has caused and thank you for reaching out. Kindly please try to power off your DJI Mavic Air and leave it to rest for about half an hour, then restart the said DJI drone and calibrate the IMU once again. If the same error ( code error 13 ) persists, I would recommend for you to contact our DJI support team at https://www.dji.com/support for further assistance. We will do there best to check the said DJI drone and give out the best resolution for this issue. Again I am sorry for this trouble and thank you.
DJI Stephen Posted at 8-24 20:11
Thank you for a prompt answer. I did the procedure and the problem persists. I will contact the support.
Hi, there. Sorry for your inconvenience. May we know more details about your issue? Have you tried to follow the steps provided on 2# to see if it works?
DJI Thor Posted at 2022-8-11 04:41
I have the same problem and no way to fix it! Help!
AK Visuals Posted at 11-10 21:05
im having the same issue i've tried calibrating in a cold room, when the temp are cold outside but not freezing i'm still having the same issues.
Hi there, thank you for reaching out. We would like to know some specific details with you. Thanks.
1. Your device model
2. The temperature at that time
3. Have you tried to refresh the firmware and re-calibrate again?
Hi, I have the same problem:
-) DJI Mavic Air 1 not used for several months - bat empty
-) Charged bat and tried to fly -> IMU Calibration required
-) Calib fails with Error 13 outside (27°C) and inside (18°C)
-) Updated Firmware to latest Version 1.0.1.0
-) Waited 1 hour to cool down the drone
-) Calib still fails with Error 13 inside (18°C) and outside (27°C)
Anyone solved this problem? This vid
[ Youtube: How to fix Main controller data error Dji Mavic Air/IMU calibration error Fix/Drone data error fix ]
seems to have a solution, but as it involves tearing apart the whole drone, I would like to avoid this.
Waltraud Posted at 5-6 02:22
Hello, there. Sorry for the inconvenience.
Please restart the aircraft, and place the aircraft on a horizontal plate to calibrate IMU.
If the calibration fails multiple times, you are advised to send the aircraft back for inspection and repair.
Here is the link to apply for an online repair request: https://repair.dji.com/us/repair/index
