M30T - High Resolution Grid Issue
djiuser_XW8hrKSQkonM
Flight distance : 1460925 ft
We are conducting some flight tests with our new M30T and the high-resolution grid function does not seem to be working properly. It seems like, at any angle, each photo taken in the high-resolution grid function seems to be shifted "up" and not representative of the true location.
I found in the M300 RTK known issues list that any high-resolution grid exceeding 50 degrees would result in a displacement error, but the error on the M30T seems to occur at any angle, the error seems to get more extreme the closer to Nadir the camera gets.
We find this especially frustrating as it's an advertised feature for the M300 & M30T that doesn't work and DJI would've had to have known when they released the M30T that this function doesn't work as it should. Our commercial workflow was designed around this function and now, our imaging operations have to be conducted manually, increasing client costs and flight difficulty to replicate a similar result.
Would be interested if anyone else has experienced this,
Thank you
2022-9-7
Nilich
I found exactly the same problem when testing high resolution grid option on M30T. Have to fly manually for tall building fasade inspection.
2022-10-1
Craig_Tas
Flight distance : 2998255 ft
Ours a blurry mess when using the function, the centre shots are clear and sharp but the more it moves to the outer edges of the grid it becomes blurred in all the shots.
2022-10-2
Robbie gilmore
New Zealand
Hi there, do you know if this has been resolved? Thanks
2023-7-18
DroneM30T
The high res grid function is awful and definitely not as advertised.  Try using it at -90 degree for roof inspections and it provides worthless pictures.  Not only does the high res grid not work properly but I just bought my m30t 3 months ago at 14K and the price has already dropped over 40 percent.....dji should credit recent purchasers.
2023-8-6
EDSC
Flight distance : 2799295 ft
Same here. I tested it again today and it is way off. There must be a way to calibrate it? And I looked for a used M30T for a few months that was worth purchasing. Nothing. As soon as I did buy one full price, I found one for literally 1/2 price used.... of course.
4-27 16:57
