Hello i have a problem with offline maps, i download the right version like 4.3.14 but when i go to click on icon offline maps this loading continuesly
We apologize for the inconvenience. I have sent you a link to the firmware. You may download the firmware of the remote controller with a screen (GL300E) to the microSD card, and then update the firmware manually. Refer to the image below for detailed steps.
1. Import the file “update.zip” into the microSD card.
Note: If the upgrade fails via SD card, please copy the update.zip file to the internal memory of the remote controller and try to upgrade again.
2. Power off the remote controller and insert the microSD card.
3. Power on the remote controller and tap “Install”.
See if it solves the issue.
DJI Susan Posted at 12-18 06:44
it work!!!! i'm so happy thank you so much!! you are the best of the world
DJI Susan Posted at 12-18 18:52
Thank you for your update, happy to hear that the issue is solved. Should you need further assistance, please feel free to ask.
good evening, I have the same problem as Paolo, I don't see the maps on the remote control with display, could I also have the file to download?
Thank you
djiuser_3FUh4vafiUVD Posted at 4-28 09:46
Thank you
Hi there, I sent it to you through PM, you can take a look and follow the steps in 4#.
