James6782
Hi, I'm loving the Pocket 3, but when I slap on the ultra-wide magnetic lens, the distortion makes the image almost unusable, and the regular wide angle is not quite wide enough for my use case (real estate).
What's worse is that the distortion is not uniform across the image, so even when applying the Lens Distortion filter in Premiere Pro, it's impossible to get all your vertical lines straight. It's almost like you would need a compound/variable version of that Lens Distortion correction in order to truly fix that ultrawide.
Any ideas around this?
- Is there another filter in Resolve or Final Cut that can help?
- Is it possible to get a little wider without putting the ultra wide lens on?
- Is there a future firmware update coming that will correct distortion in camera?
