DJI MIC 2 Inconsistent Recording of Audio
387 6 2-9 11:02
Jxmes123
Hello,
I ordered the DJI Mic 2 last week and have thoroughly enjoyed using it. I was using it with an iPhone 13 Pro Max and it was working perfectly. However, a few days ago I took the transmitter out of range and ever since then, it's been very inconsistent. I will record a video and it will be fine, I'll record another video a minute later and the audio will come from the iPhone's microphone and not the DJI Microphone. No change in what I do, just behaviour of the microphone.
Does anybody have the same issue or could let me know a fix? Very important!
Thanks,
2-9 11:02
DJI Tony
Hi there. Sorry about the trouble. Will it be fine if you post a sample of the audio? You can upload it to Google Drive or YouTube and then paste the link here. Thank you very much.
2-10 21:05
Jxmes123
DJI Tony Posted at 2-10 21:05
Sorry, I don't know how to do that.
I bought a new set but it's exactly the same problem. I will record for 2 minutes and it's fine, stop for about a minute, record again and then when I check the last clip back, it goes back to the original iPhone audio.
Have you found a solution for this? I sent the first ones back but it's also happening on the new one as well.
4-5 14:52
DJI Tony
Jxmes123 Posted at 4-5 14:52
Hello. Thank you for the update. If I may confirm, The Transmitter auto-off was just recently added to the firmware. When enabled, the transmitter, when not connected to any device and without independent recording activated, automatically shuts down after 15 minutes of no use, does this apply to what's happening to yours?
4-6 02:19
OnePixel
Flight distance : 45049 ft
Good morning, in which sub-menu is the auto-off setting? Thank you very much for your answer
4-6 23:30
TripleFlacko
Bulgaria
@DJI Tony
You say 15 minutes, but mine stopped recording after 10 minute break. My last video that has the audio from dji mic 2 was recorded at 21:53 and it was 29 seconds long, then at 22:04 i have another video and it has the iPhone audio in it, means the transmitter turned off after 10 minutes of idle while it was connected to the receiver... I wasted 1 hour of recording time and 7 scenes out of 8. I'm very disappointed. I updated the software today and turned the auto turn off feature off.
But. As i have said it was only 10 minutes break, i have the videos and the recorded times. Also you say it turns off if it's not connected to any device, but it was connected to the receiver!!!!! Please explain, why is that happening, i don't wanna waste my time like that!
4-21 06:28
Shamsad
United Arab Emirates
DJI Mic 2 Auto Disconnect from Iphone
I am facing auto disconnection with iphone and receiver.
The mic will work properly for the first time after connecting. If you stop video recording and start re-recording, the mic will be disconnected. Even if the video recording is turned off and on for a while, the same problem occurs. The DJI mic is switching to the iPhone mic. Is there any solution for this?
4-29 21:44
