alex mass
patiam Posted at 4-8 07:45
Before UAS, I spent 20 years doing nearshore bathymetric mapping using various sonars, ROV, etc. The new Yellowscan bathy lidar is definitely a breakthrough, being the first such payload that can be carried by sUAS.
I've done a bit of U/W photogrammetry as well. I'd be surprised if you can achieve what it is you're after using UAS. I understand the desire to speed up the data acquisition over what a swimmer can achieve, but I don't think you're going to be able to go much faster using a drone and still get the required number of images with the needed overlap and image quality. Seems like a pretty significant risk of a not inexpensive drone for what might be a minimal efficiency increase. But good luck if you try it! Personally I'd look at a small skiff with an electric trolling motor or somesuch. Cheaper, safer, and simpler. If you want to get "fancy" and keep folks out/off of the water you could fashion or buy of the shelf a small autonomous boat (ASV).
Thanks for your comments and pointers.
You are perfectly right, the flying speed will not be much faster than a swimmer. We spent many (and many !) hours in the water, pushing a raft with a stick to acquire photos. And swimming within a 30 cm lane for hours is not an easy task.
Positioning the camera is described in the links above. Having a precise location is key for the reconstruction computing times (the area we aim at is 100x100 meters).
Finally, water visibility changes pretty fast in our working area. When conditions are met, we aim to survey the largest possible area the soonest.
Some tried the boat, but it offers other constraints.
And we will give a look at Yellowscan! Even if we don't look at the price tag for the moment (it certainty is heavy). For some archeological sites, it might really be a killer. While we still need to challenge the image precision for others.
Thanks again,
Alex |
