fans3ebf65f7
I'm running mapping missions of fields with an M3M in advance of spray season, and I'm using Terra to prepare spray missions on a T40. The reconstruction looks great, and I'm able to create my maps successfully. I'm having two problems, one is intermittent and one is constant.
The intermittent issue is that on some missions, when I go to 'Modify Result' in the dropdown list (Water/Pole/Other/Field) sometimes the 'Field' option is missing entirely. Why would that happen?
The constant (and bigger) issue is that when I attempt to create a route, Terra ignores all of the modified results. I've blocked off water areas correctly, field areas, poles, etc. (and have saved after doing so) but when Terra generates the route, it just runs right through or over all of those obstacles/areas. It's essentially just a waypoint mission that completely ignores the mapped areas.
Any insight into what is occurring?
