Plasmo
Flight distance : 17907 ft
Dirty Bird Posted at 5-5 06:39
I assume in the Advanced Camera Settings (in the Goggles 3 menu) you are set to auto-record on BOTH?
If that is true & it is only recording 30 seconds on the drone before stopping, then you may have a flaky memory card. Try reinserting the card into the drone then reformatting it in the drone.
thanks for the reply.
Yes, the setting is set on "both".
I will try reformatting the sd card and trying again. I'll also try swapping the avata2 and goggles3 cards to see if is the card, but it should be ok - sandisk extreme 128gb Class10 U3 V30 A2 in both. |
