The Matrice 30T drone is prematurely returning home before the displayed flight time remaining elapses. This issue occurs inconsistently and impacts the drone's ability to complete missions effectively.
- Plan a flight mission for the Matrice 30T drone.
- Ensure that the flight time remaining is displayed accurately on the control interface.
- Start the flight mission.
- Observe the drone's behavior as it progresses through the mission.
- Note that in some instances, the drone begins to return home before the displayed flight time remaining has expired.
Expected Behavior: The Matrice 30T drone should continue its mission until the displayed flight time remaining reaches zero, unless manually instructed otherwise by the operator. Actual Behavior: The drone initiates its return home procedure prematurely, sometimes significantly before the displayed flight time remaining reaches zero. Are there any settings I can adjust to fix this issue?
