sd card for the Avata 2
1527 8 4-24 10:08
fansbccecf3f
i purchased  sandisk ultra micro sdxc no thye package it stats 140 mbs but there is a worning on the goggles of slow sd card  what should i use
4-24 10:08
fichek
Flight distance : 984478 ft
Croatia
It's been a rare problem since the first DJI FPV System that sometimes randomly happens. I use those same cards (it's even in DJI's list of recommended cards) as well as other SanDisk models, and never had issues except with one original FPV Air Unit. Sometimes it goes away when you format the card inside the device itself, so try that first. Good luck.
4-24 11:28
DJI Gamora
Hi, fansbccecf3f. Thank you for reaching out. Here's the list of the Recommended microSD Cards for Avata 2:
Hope this helps.
4-24 19:06
djiuser_VYsIL9KYpRzx
Flight distance : 3491 ft
fichek Posted at 4-24 11:28
How do you format the SD card in the Avata 2 drone.
4-25 08:06
The Duck
I've been using SanDisk Extreme cards on my Avata 2 and Goggles 3 and haven't had any problems yet.  I've had slow SD card warnings with Sandisk Ultra cards even on my old V2 Goggles.
4-25 08:55
fichek
Croatia
djiuser_VYsIL9KYpRzx Posted at 4-25 08:06
Settings - Camera - Format - select the aircraft SD and confirm.
4-25 11:33
DJI Paladin
Flight distance : 318 ft
Hi there. Thank you for reaching out. We recommend backing up all the necessary files on your SD card before reformatting. You can reformat your SD card using your computer or format it directly on the Goggles, when DJI Avata 2 and DJI Goggles 3 are powered on and linked, access the goggles menu and navigate to Settings > Camera > Format to initiate the formatting of either the microSD card or internal storage. Please remember that before proceeding with the formatting, it is crucial to store and create backups of your data to prevent any potential loss of data. Hope this helps.
4-26 19:36
djiuser_YX4smwxK76wY
You can format the SD card by going through the setting the the goggles 3 i cant remember where but i remember scrolling down
4-27 15:26
A J
Flight distance : 14312858 ft
I always use sandisk extreme pro U3, A2, V30 and never have any problems.
4-29 04:43
