New DJI Mini 4K Firmware Released (04/29/2024)
2070 26 4-29 23:55
DJI Support
Flight distance : 2408 ft
Overview
  • Date: 2024.04.29
  • Aircraft Firmware: v01.07.0400
  • DJI RC-N1C Remote Controller Firmware: v01.00.0100
  • DJI Fly App iOS: v1.13.1
  • DJI Fly App Android: v1.13.1
What’s New
  • Added support for Remote ID requirements of some countries and regions.
  • Fixed some known issues.
Notes:
  • If update fails, restart aircraft, remote controller, and DJI Fly or DJI Assistant 2 (Consumer Drones Series), and retry.
4-29 23:55
fichek
Flight distance : 984478 ft
Croatia
When is this drone gonna be available on DJI online store?
4-30 03:34
DJI Gamora
fichek Posted at 4-30 03:34
Hi, fichek. Thank you for your interest in the DJI Mini 4K. This product is currently not available on the DJI Store. If you are interested in purchasing it, you can inquire about it and make a purchase through Amazon US and Amazon EU. Towards the end of April, the product will be purchasable on Amazon US and Amazon EU. Additionally, by mid-May, it will also be accessible for purchase through authorized retail stores in the US. Thank you for your attention and support.
4-30 23:57
BobWinNV
Flight distance : 301250 ft
Is Mini 4K RID compliant in USA?
5-1 12:42
fichek
Croatia
BobWinNV Posted at 5-1 12:42
Excuse my overseas ignorance, but isn't the whole point of sub-250g in US not needing RID?
5-2 18:26
BobWinNV
fichek Posted at 5-2 18:26
No
If you fly it under part 107 rules you need RID regardless of weight.
5-2 19:48
fichek
Croatia
BobWinNV Posted at 5-2 19:48
No
Ah I see. In that case, it looks like the answer is no, since according to the FCC filing the only changes in Mini 4K vs Mini 2 SE are new 4K camera module and new part numbers (with same functionality) for 2.4 and 5.8 wireless chips: https://fccid.io/SS3-MT2SD22/Letter/C2PC-Letter-7211456.pdf
5-2 20:08
BobWinNV
fichek Posted at 5-2 20:08
Not necessarily as the FCC filing is for RF transmissions (frequencies, power, modulations,, etc.).  I think that the RID (a FAA requirement) is not modifying anything covered by the FCC.
Anyway DJI said  that the last firmware release turned on RID for some countries I was just wanting to know if the USA is one of those countries.
5-2 22:39
fichek
Croatia
BobWinNV Posted at 5-2 22:39
Yeah what I meant was if Mini 2 SE doesn’t support it, hw is the same on “Mini 4K”, fw update doesn’t mention it, and DJI Support documents say Mini series lower than 3 don’t do RiD, then it’s safer to assume it isn’t there.
5-2 23:40
DJI Gamora
Hello, BobWinNV. Thank you for reaching out. This drone is not provided with the RID function. To fly with compliance, you can fly within FRIAs or acquire a third-party RID module on the FAA DOC audit list and then retrofit it to your drone.
5-3 00:26
BobWinNV
DJI Gamora Posted at 5-3 00:26
Does this mean that we will be seeing a lot of USA based YouTube Mini 4K reviewers fined by the FAA in the near future for breaking part 107 rules with their YouTube reviews of the Mini 4K?
5-3 05:21
DJI Gamora
BobWinNV Posted at 5-3 05:21
Hi, BobWinNV. For this, you may go to this link or contact the FAA for their procedure.
5-6 22:36
BobWinNV
DJI Gamora Posted at 5-6 22:36
The FAA says that I may not fly this drone under part 107 unless I add a RID system. So I may not use video shot with the Mini 4K on YouTube in the USA unless I modify the Mini 4K to transmit RID and I register the Mini 4K as a Part 107 drone.
5-7 17:41
DJI Gamora
BobWinNV Posted at 5-7 17:41
Hi there. Yes, as mentioned above, to be able to fly with compliance, you can fly within FRIAs or acquire a third-party RID module on the FAA DOC audit list and then retrofit it to your drone. You may also contact the FAA for further checking/assistance.
5-8 07:31
BobWinNV
DJI Gamora Posted at 5-8 07:31
Yes, you can fly recreationally in a FRIA but video captured can not be used for commercial purposes (YouTube).
5-8 11:04
DJI Gamora
BobWinNV Posted at 5-8 11:04
Hi there. For commercial purposes, we highly suggest installing a third-party RID module. Thank you for your kind understanding and support.
5-10 06:46
StarBuks
DJI Gamora Posted at 5-10 06:46
In the SUPPORT section of DJI we find this information:
(SEARCH FOR THIS: "17. How do DJI Mini series users comply with the Remote ID rule?")
• DJI Mini 4 Pro & Mini 3: These aircraft support the FAA Remote ID functionality. However, for the latest aircraft firmware (v01.00.03.00 for Mini 4 Pro and v01.00.04.10 for Mini 3), the Remote ID will only be activated when the Intelligent Flight Battery Plus is used.
So it appears that for RID to be enabled it must be flying the larger battery.
This will automatically put you in a higher weight class in the USA.(I wish this was the behavior of the Mini 3 PRO)
DJI : Please confirm this - there appears to be discrepant information here.
5-10 08:25
BobWinNV
I was talking about the Mini 4K which does not have a larger battery.
5-10 16:11
BobWinNV
5-10 16:11
EmilP
Finland
Where I can download firmware?
5-12 14:15
DJI Gamora
StarBuks Posted at 5-10 08:25
Hi there. Are you referring to this website? If yes, rest assured that the information is correct and please note that BobWinNV is referring to the new release drone which is the Mini 4K. Hope this answers your question.
5-13 06:35
DJI Gamora
EmilP Posted at 5-12 14:15
Hi, EmilP. Thank you for reaching out. The firnware update should be automatically detected once you connect the drone to DJI Fly (with internet access). If it fails to do so, you may also use the DJI Assistant 2 (Consumer Drones Series) to update the drone via PC.
5-13 06:44
djiuser_3LQ5P0ZDoeT8
I'm curious, you say the Mini 4K is not provided with RID function, yet the first post at the top of this thread is a firmware release notification stating they've "added support for Remote ID requirements".  So there's support for RID, but no actual RID?
5-15 08:43
DJI Gamora
djiuser_3LQ5P0ZDoeT8 Posted at 5-15 08:43
Hi, djiuser_3LQ5P0ZDoeT8. Thank you for reaching out. The added support for Remote ID requirements of the v01.07.0400 firmware version is for some countries and regions only such as Japan and China for example. The RID in North America is not supported via firmware thus, it is required for a third-party RID module.
5-15 23:37
Dunright
Is DJI assistant  available for the new mini-4k?
yesterday 08:43
DJI Gamora
Dunright Posted at 5-18 08:43
Hi, Dunright. Thank you for reaching out. Yes, you may check it here: DJI Assistant 2 (Consumer Drones Series).
yesterday 22:59
djiuser_ukd1g8whPAvm
IS IT NOT TIME TO UPDATE THE OFFLINE MAPS IAM GETTING SO DAMM TIRED OF THIS BEING IGNORED I ALONE SPENT 5 HOURS TRYING TODAY IN CANADA TO GET AT LEAST ONE 2.8 MB DOWNLOADED STOPPED AT 28% AND NOW AS IT WENT TO SLEEP ALL IS GONE SO TIRED OF THIS AND SPENT ALL TOGETHER FOR EVERYTHING EXTRAS YOU NAME IT 4,000 AND I DONT HAVE ACCESS TO ANY MAPS ?? WHAT THE?? THIS HAS BEEN GOING ON FOR YEARS ITS TIME TO LOOK AT YOUR CUSTOMERS HERE  BUY THE API AND GIVE IT TO US ONCE AND FOR ALL MINI 4 PRO PLEASE DO NOT SAY WE ARE SORRY AND OUR ENGINEERS ARE GOING TO LOOK AT IT WHAT?? HAVE THEY ALL BEEN ON HOLIDAYS SINVE 2019??? PEOPLE HAVE GOT TO LOOK AFTER THEIR CUSTOMERS OR THEY WILL ALSO LOOK AT OTHER DRONES YOUR TURN (DJI)
9 hours ago
