Zbig
Flight distance : 7349 ft
Poland
Guys, hear me out. There's so much confusion, half-truths, speculation and plain misconceptions in this and other threads regarding charging, it's not going anywhere and doesn't help anyone. Let me briefly explain the basic concepts behind charging batteries in modern devices. I'll talk about DJI Spark specifically but the information applies to broader range of electronics like smartphones, etc. Charging the DJI Spark or any modern, properly designed USB device is nothing like charging your car battery.
The thing is, you don't get to decide the battery charging current directly by connecting USB chargers with varying current capacities. Actually, the term "USB charger" is a bit of a misnomer and that doesn't help understanding things, either. USB charger is, in fact, just an AC-DC constant voltage power supply that is capable of providing electrical current up to the value printed on it, if needed and asked for. The actual charging circuitry is on the other end of a cable: in the Spark itself and its intelligent flight battery. The fact that you connect a 5V, 2A USB charger doesn't mean that the battery sees a constant current of 2A during the duration of the charge. It only assures that the charging circuitry inside the Spark and the battery has enough power available at its disposal to do its work properly. Again, it DOESN'T MEAN YOU'RE CHARGING YOUR BATTERY AT 2A. The charging process of a Li-Po battery is very critical and it can be dangerous if not done in a proper, strictly controlled manner. That's why neither you nor the USB "charger" (USB power supply) control the battery charging process. USB supply's only job is to provide a stable voltage at the current UP TO the value stated on its case, if and when the device being charged requests it. Towards the end of the Li-Po charging process, the charging current tapers off slowly as the battery fills up and when it diminishes to some specific, low value (like one tenth of the original charging current), the charging process concludes. This (the gradual decrease in charging current, down to almost zero) does and will happen regardless of the USB charger being used.
To put it another way: the mains socket on your wall is capable of providing, say 16A of current at 230V for the maximum theoretical power of 3860W. You can plug both a small LED desk lamp or a washing machine there and they will both work, right? Needless to say, the current being drawn by the washing machine is many times higher that the current being drawn by the LED lamp, right? How do you think does that work? How's it possible that the desk lamp doesn't blow up to smithereens once plugged to a "power supply" (the socket in your wall) capable of powering a washing machine? Do you think it is the mains socket that "decides" the current that will flow to the device? Or perhaps the device being plugged in it governs that?
The USB charger juggling described by the OP is a pointless exercise and a waste of time but of course it's your time to waste.
