Andrea DJI
Hello everybody.
I tried this set up:
Ronin 2 with DJI transmission, high bright monitor on a fluid head, gyroscope control on.
Everything is fine until I slowly pan left, when I stop panning, the Ronin start drifting back to the right, only with slow pan, if I move it faster either fine, but in this conditions is not suitable for professional use.
I tried to change every setting possible on the high bright monitor and on the Ronin itself, nothing change it.
I calibrate Ronin and high bright monitor gyro multiple times but nothing solved it.
Even tried to switch remote channels setting pan on the tilt channel and, the issue was still there.
It has to be a problem with the high bright monitor gyroscope I guess, cause the only thing that make the drift stop is switch off gyro control immediately after the pan.
I really need help, does anyone have experienced same issue ?
Please DJI expert say something
