knupla2
Looks can deceive. We've been out photographing that windmill for years trying for the right sunrise/sunset shot across the prairie. It a shorty with it's platform reachable from the ground. Here's a shot my buddy took of me reaching the platform from the ground in 2009. You'll also notice the stock tank it used to pump to is gone. The well is dry and the windmill is locked. It takes at least a 20 mph wind to overcome the brake and make it turn at all. The vane is pinned so it won't turn with the wind.
If you go back and look at the video again, you'll see at the start in the background, the windmill starts turning [that was the first clue I shouldn't have tried to fly it]. You'll also notice at :34 how much wind gust I'm fighting by the angle the P3P takes to get to the windmill [we call that another clue this was stupid to fly at that point]. At 1:07 you can see the wind trying to move the pinned vane, and the windmill starts turning again at 1:10 [another of those "clues"]. You can also notice the windmill speed changes several times and the vane is trying to move back and forth as the winds shift.
This was just another one of those stupid human tricks. Had I used common sense, I would have never launched in the shifting winds at ground level - knowing full well what happens as they shift across the open prairie in NM.
However, you're incorrect thinking I flew into it. I checked my log to see if I did that. Log shows at that point, there was no command stick input - it was hovering.
The reason I want to make it clear to what happened is for others to understand that if you choose to fly in winds over about 10 mph at ground level, you're normally flying in winds of 15 or higher, and often gusting, at higher altitudes. If you're flying at higher elevations, over barren prairies it's worse - especially so when you get too close to something.
