fjrn
Well I can only state as i have above to First use a Friends nicer radio do all your set up then rebind the DX4e or DX4 ,, but i may have another workable solution for this issue without friends remote. This one is a little trickier.
0 MOST IMPORTANT Dont have Props on during any part of set up EVER Especially during steps 3-5 As uncontrolled ESC can fire up at any time ,and often will come on without warning, you have been warned.
1 set up Quad as per normal
2 when you get to E,A,T,R sticks simply do the normal thing.
3 when you get to X1, X2 and U ,unplug your E, A and R , and plug them into U, X1 and X2. This will allow you to control them the way to program asks
4 Unplug U ,X1 and X2 and put them back into E, A and R respective to the way they came out.
Finish programming as per normal U will set up on -1000 (stick down) and be in atti. mode always which is ok for stable flying.
5 Be sure to do keep props off till you know everything is finalized and ready for first trial. |
