sheinisch
Okay, also I have done my first flights at higher distances and heights today. I was across some open fields towards a radio-tower. Sounds worse than it was...
At a distance of app. 130m and a height of app. 40m, the connection to the app did break up. Distance to the radio-tower was app. 500m.
First it went red for signal loss and the lightbridge-video went black, then the app showed disconnected. This happened while I was recording the flight. I instantly pressed the RTH-button. On the video, which does not show any sign of failure, you see that the Phantom receives the RTH ... or decides on it's own to go into RTH-mode: It turns and and dashes back towards the starting point.
5 seconds later the connection was re-established and I could cancel the RHT. So, anything fine - but a strange feeling remains.
Regards,
*Sven*
(Firmware 1.1.8, iPad Air 1) |
