jesolins
Flight distance : 2169 ft
Hi Gents,
I have a recently bought used P3P that will not load the new firmware by the camera micro SD slot. No text files get written about the firmware load, just gets the P3P folders re-written to it. The camera and SD card slot seem to work fine otherwise. Videos and photos are saved normally to the SD card. The SD card is a 16GB c10 that is formatted (tried both FAT32 and extfat) before I put on the 1.1.9, 2.6.0, 1.3.2, or 1.4001(tried them all) P3P firmware which I have re-downloaded several time to try to get it to update. The file is unzipped on the SD card It just goes into normal flight mode when the firmware SD card is in the P3P and then the model powered on. Also I noticed that if the camera cables are connected, the Go app About firmware states firmware unknown for the aircraft. If the camera cable are removed it will show the aircraft firmware as 1.8+ The Go app is version 2.41 and the RC controller was updated to 1.3.2 normally. I have also tried to use the service.bin to correct this issue but no joy with that either... It flies and works fine except for not being able to get updated firmware on-board.
Does anyone know of an alternate way to load the aircraft firmware? Has anyone tried to load it via the micro USB on the Phantom or the micro SD on the bottom of the centerboard?
Any thoughts or suggestions welcomed.
Cheers,
Jim |
