ben_m16
Flight distance : 5459859 ft
Tahoe_ED believe me, if it is related to the GPS.
You can see many videos on youtube confirming this, and I myself have tried.
When you have no GPS coverage everything works smooth. When you have few satellites set (and the bars are red cover) live video begins to hop.
And when you have enough satellites and turn white and bars Up tells you that you have enough coverage to fly (8 satellites or more) there begins to many problems of delays and cuts.
Please investigate this line that probably this related to one of the improvements made in version 1.1.9, where he put the drone better now determines your altitude.
Do not waste your time researching the subject of heat, which is not relevant. Here in my town I've had 40 degree days and 25 days degree weather, and the result was the same.
With version 1.1.8 I had the same tablet with the same applications and the same temperature and did not have any problem.
Investigate the point that I have said before that there surely this problem.
If you only investigate the temperature, you can never fix the problem, because in the world there are many different temperatures at all times and you can not fix everything.
And please do not write to cleanse the ram, sign-off applications, etc., because that's the first thing we did almost everyone. |
