patiam
Flight distance : 1148294 ft
@Strannik-
Glad to help a fellow marine scientist with their research!
For high-accuracy GPS on a drone you basically have 3 options:
- RTK using a local base you set up that brodcasts corrections to your mobile rover (aircraft in this case). This is what you would use the DJI D-RTK 2 base station for. NOTE: it would need to be on land or an unmoving offshore structure (not a boat), as it can't move at all during a particular data collection session once it is set up. Also, it works best if placed on a location for which you have already have high-accuracy coordinates. If using an established benchmark, those coordinates may be aavailable from the agency that installed the benchmark, or one can detrmine them using surveying methods (a long occupation with an RTK-capable GPS can use PPK to solve the corrdinates).
- RTK using a VRS (Virtual Reference Station) accessed via radio or the internet. Requires no local base station, but you must have connectivity to the VRS, and it should be nearby (~10-15km) if it is a single station. Services exist that use a network of surrounding stations to create a VRS right at your location as well.
- PPK (Post-Processed Kinnematic), which really isnt RTK at all (the RT stands for "Real Time") but with the right hardware and software can provide as good or better results after the fact (as the name implies). No base station is required as long as there is a nearby CORS (Continually Operating Reference Station - may of these are also VRS's) from which you can download data for the period you flew. Again, the important thing to remember here is that you will not enjoy high positional accuracy in real time, only after the flight is over. Depending on your requirements, this may or may not be OK.
- (There are other ways such as satellite-based correction subscriptions but implementing them on a COS DJI UAS is probably not feasible).
Regarding the P4PRTK, the jury is still out on whether it performs up to the advertised specs. In our experience, it does not. I'll post more about that later. The short story is that for photogrammetric mapping, the resulting orthomosaics and DSMs have great (2-3cm) XY accuracy & precision, but in Z it's no better than 50cm. Note that this is for the processed photogrammetry products, not necessarily the instantaneous accuracy of the AC positioning. But something is not working right in the system at this time.
As for lasers, yes green would probably be the way to go. They need to be parallel and as close to orthagonal to the CMOS plane as possible (at least along their axis). I saw in another thread you were looking into laser rangefinders. Good call, that's another possbile way for you to get your distance above the animal so you can determine scale. Bottom line (as you know), the P4's barometric sensor is too noisy and inaccurate for your needs.
