DroneEEE
Flight distance : 1047 ft
Sweden
jonny007 Posted at 3-1 09:25
Oh, I forgot to mention that Litchi only supports the Mini 1 so far, sorry. But taping the sensors is always possible, no matter which drone or app ;-) In fact, it is often BETTER to deactivate VPS, because this prevents incorrect measurements. I've had strange up and down movements near the surface of the water, especially when the sun is reflected in the water. This does not happen with taped VPS sensors, here you can theoretically fly 1 inch above the water surface.
Another disadvantage of VPS: e.g you fly so slowly through a narrow window frame that the VPS responds> the drone jumps up and hits it. 2 options: tape sensors or fly faster.
I also feel that it's better to deactivate VPS as long as it doesn't cause glitches, but it seems like it won't.
I agree with all the possible scenarios you mention. It may be good for beginners, but I don't like the drone taking action on its own. I may very well be flying under a structure that it would otherwise hit. |
