DJI Gamora
Hi, there. Thank you for reaching out. Could you tell me the model of your phone using now? You can troubleshoot the problem through the following steps.
1) Check whether the mobile phone is on the compatibility list.
Compatibility list link: https://dl.djicdn.com/downloads/ ... ibility_List_en.pdf
*If it is not in the compatible list, please verify the weight (230 ± 60 g), thickness (6.9 to 10 mm), width (67 to 84 mm) of the phone.
2) Remove the phone case and try again.
*As the mobile phone case may be soft, the clamping position of the mobile phone clamp may shift.
3) If the mobile device is small or thin (such as an iPhone 8, Nova 8, or OPPO Reno 5 Pro) or the mobile phone edge is arced, use the provided riser pad.
4) If a high temperature prompt appears in the app, it indicates that the motor enters self-protection status. After the above three steps have been checked, please restart the gimbal and DJI Mimo, and the issue can be resolved.
5) Use the magnetic phone clamp correctly. Make sure that the phone clamp is in the middle of the phone. Attach the magnetic phone clamp correctly to the gimbal.
Please pay attention to the following points:
1) Ensure that the magnetic phone clamp is in the middle of the mobile phone (via visual inspection).
2) Ensure there is no gap between the mobile phone and the magnetic phone clamp and that the magnetic phone clamp properly secures the mobile phone.
3) Ensure the dot on the mobile phone clamp aligns with the white dot on the gimbal.
If you have any other issues, do not hesitate to contact us. |
