mifish
Flight distance : 456188 ft
Well - lets think about this some more.
Simply Changing the pitch of the goggles could result in change in camera orientation. No translation of the flight controls would be required. Flight controls would behave as normal; the change in camera angle is akin to commands from the controller.v2-gimbal-dial.
Yaw would be more complicated. Change in Goggle yaw orientation, could result in an yaw input control of equivalent orientation... So as to keep the the spacial orientation of the drone the same you could modify the control system in a few ways .
1 - Modify the drones internal orientation ( akin to having shifter the gyros )
2 - Translate the pitch and role inputs as received the controller.v2. This translation would be simiar as to if you had pushed the right stick ( assuming a mode 2 controller ) an opposite number of degrees as the current Goggle yaw. (eg/ if the Goggles were yawed 90degrees to the left (counter clockwise), you would need to shift the right stick orientation 90 degrees to the right (clockwise).. Thus a full forward right stick input would be translated into a full right, right stick input.
If there is an obvious flaw to this logic, please let me know.
If this sounds correct, please also let me know.
Cheers |
