pianist
Flight distance : 37956 ft
Denmark
So - I really need a lens hood on my P3P. It's not possible to get decent shots without flares or prop interference even in light backlit sunny conditions - which for me is a bummer since those conditions can be so beautiful if planning your shots carefully. I don't understand why DJI don't include a lens hood - after all the camera is almost up to professional standards, especially the wide angle lens, but it's not a professional product without a dedicated lens hood. Every serious DSLR wide angle lens comes with a delicately designed lens hood and it would NOT add anything to the cost! So I fiddled around with cardboard for some time, adjusted, readjusted, finte-tuned - and came up with this. The shape takes into consideration the nature of the wide angle lens and gives you almost linear blinds. I have NOT tested it yet, so it's still theory! - but will keep you up-to-date! Of course, despite the lens turning its nose down when powered off, the gimbal motors have no issue holding it since it's so light. However you need to power P3 up with plenty of space beneath the camera to let the camera do its calibration routine without hitting anything. For example placing it on your backpack over some of the cuttings. Or simply mount it when powered on. If I succeed with this design I can provide a PDF for you so you just print and cut!
