LV_Forestry
Flight distance : 4726654 ft
Latvia
Aksel Smaksel Posted at 1-13 01:45
Its just that there's not a lot of space so the drones, batteries, chargers and all just lies around.
I live in Denmark, Scandinavia. Do you know a what moisture % could lead to harming the batteries?
I will translate DJI Wanda' answers, it is not recommended to charge a battery if the temperature of the elements is not between 5 and 40 degrees Celsius.
When it's cold, between -10 and 5 you can charge your battery without problem between two flights, the battery having heated up during the flight, the elements are at the right temperature. You can check it in the app.
What worries me the most is that you will put the battery to charge outside, it will charge in less than an hour and the rest of the night it will go to local temperature. First, there is a risk of condensation if you bring your batteries inside where it is warmer. Secondly if it is below 15 degrees, the elements will not be hot enough. The app will notify you that the battery is below the recommended 15 degrees.
Good job DJI Wanda, there are the words "outside" and "temperature" in your answer. Don't be surprised that people think you are bots.
