DJI Gamora
Hello, there. We're sorry for the trouble that it may cause you. Currently, the DJI Assistant 2 software doesn't support Mac equipped with an M1/M2 chip. As for Windows computers, you may follow the recommendations below:
1. Make sure to download the correct DJI Assistant 2 software via this link.
2. Make sure the connected device is powered on.
3. Reinstall the DJI Assistant 2 software.
4. Turn off the Firewall. (This step is only for Win.)
5. Replace the USB cable connected to the unit and PC.
6. Install the driver manually, here are the steps: (This step is only for Win.)
① Unplug and plug in the USB cable or use another USB cable. --> In WIN7 or a later system, turn off the antivirus program on the computer. Reinstall DJI Assistant 2. --> Manually re-install the driver.
② Right-click “My Computer” --> “Administration” --> Select “Device Manager”, and check the drivers that should be installed in Windows (as shown in the figure).
7. Please replace the computer if possible.
If you try all the above actionable methods and the connection still does not respond. Please send the units back to us for testing.
I hope this information helps. Thank you for your support. |
