Pepijn
Flight distance : 1383189 ft
I shoot in pro mode. and do all camera settings (resolution, frame rate, shutter time, iso, F stop) manual.For the camera I use ND filters to set my shutter time as I desire, but I have to copy all the camera settings manual to the three different lens choises.
When I change the lens on the mavic 3pro, I have to set the settings again. Why are the settings not all the same for all lenses, when I change the lens ?
Yesterday I prepared my settings with the wide angle lens, needed to deliver 1080 shots. I change lenses in flight, and forget to set the resolution again to 1080, so ended up with 4K for the tele lens and 1080 for the wide lens.
The funny thing is that the White Balance setting is the only one for all lenses. Everything else you have to check and do again three times (lens: 1, 3x and 7).
I would like a setting that set's the camera settings (resolution, frame rate, shutter time, iso, F stop) for all lenses the same.
That would be a great improvement in the next firmware.
