DanielMyst777
Flight distance : 145276 ft
On the newest battery firmware (v1.1.410), if running the P4 intelligent flight battery down to critical battery levels ~10% charge and try to charge the battery from this low voltage with a standard phantom 4 battery charger, the battery will give a high-voltage error (only the right most light will illuminate and blink three times fast, pause, and blink three times fast again over and over) for a little bit until the charge is around 15-20% then it will show one LED light and show normal charge light indicators. I have tested this on two different batteries both updated to the newest firmware mentioned above. It did not do this behavior on the previous battery firmware when draining and charging the battery less than 10%. It would just blink the one left most LED quickly to indicate current charge and activity.
