dansteidl
same issue, double beep constantly when i turn it on and the green yellow and red under lights cycle over and over as it's beeping after a completed update. The light on the front of the gimbal is solid green. I got the success message from the update. It appears all updated correctly but something just isn't right now. I have updated the firmware in the past with no issues, now this update seems to be causing a lot of people issues.
========== 2016.06.19 03:43:22 =====================
Packet: P3X_FW_V01.09.0060.bin
Upgrading ...
Result: Success.
The only thing the controller does is tilts the camera, I have no other controller functions other than that. If I put the card back in with the firmware, it tells me it already is up to date.
========== 2014.01.01 00:00:11 remo-con disconnect======
Result: Abort.
The firmware on the SD card is identical to or older than the current firmware on the aircraft.
It was working fine right before I updated. I also updated the remote through the app, and now I can't even get the remote to recognize that the iPad is even plugged in, anything that I plug in to the usb on the controller doesn't even light up. It's as if the remote update broke the USB port, and I am seeing 100s of other people on the forums saying the same thing. I am on the newest version of the Go app and the newest version of iOS. |
