Nigelbrinkmann
Flight distance : 586391 ft
paulofthenauth Posted at 2016-12-5 12:42
Hi Mindy, thanks for your quick reply. My mobile device is a Panasonic Lumix DMC L1 running Android 5. I have been using this device since I bought the P4 back in July with no problems until recently. I have not installed DJI GO 4. I am using App 3.1.0 Version 01.02.0503 and RC is 1.6.0. My default video setting is 4K 3840x2160, 1 down from highest setting. I have cleared the cache, turned off recording to device, tried different cables, put the device in airplane mode to avoid any internet interference. I have attached a brief video as requested taken this morning. I didn't fly it, just moved it around by hand and no problems. If it is going to be problematic it happens on start-up before flying and this is my testing method. You will notice some odd colours and lines appear on the video. These do not get recorded to the card, only the device and has been doing this since I bought it. Hope you can come up with some ideas.Paul Curtis P4 test for Mindy
As said above the device may not be compatible,the DJI go app requires a lot of grunt to operate, it is a device problem, you mentioned that the SD card footage is fine. |
