wkjiii
I bought another P3P and it came with A/C 1.5.3+ and R/C 1.6. From what I've read, I went to A/C 1.8.8 from the DJI site to mate better with 1.6. However, when I did, it showed up as 1.8.8+.
The results file showed:
"Packet: P3X_FW_V01.08.0080.bin
Result: Abort.
The firmware on the SD card is identical to or older than the current firmware on the aircraft."
So my questions are:
What does the "+" mean. I've read it means something on the A/C is at a higher level (battery, camera), if so, how do I get rid of the "+" or does it matter if I fly with a higher level on these items, and
from the error message, is my firmware really 1.8.8 or something higher (which, again from what I've read, I really don't want that).
I have reloaded the go app with same results. my log file has this:
[00012778]========== 2017.04.04 20:23:18. boot(15) ============
[00012848]Packet [C:\P3X_FW_V01.08.0080.bin] detected, card sn [0x2a05a8e0].
[00012920]Packet upgrade start...
[00012998]Packet checking...
[00013069]Packet vlink 01.08.0080 <-> 01.07.0060.
[00013142]Record vlink 01.08.0080 <-> 01.07.0060 (flow = 0).
[00013214]Done.
[00013286]Version checking[1]...
[00013421][03 05][00] v34.2.0.9 -> v34.2.0.9
[00013535][03 06][00] v2.4.20.22 -> v2.4.14.5
[00013619][04 00][00] v1.44.0.0 -> v1.44.0.0
[00013755][11 00][00] v1.7.15.1 -> v1.7.15.1
[00013863][12 00][00] v1.10.0.0 -> v1.10.0.0
[00013986][12 01][00] v1.10.0.0 -> v1.10.0.0
[00014110][12 02][00] v1.10.0.0 -> v1.10.0.0
[00014225][12 03][00] v1.10.0.0 -> v1.10.0.0
[00015055][15 00][00] v1.1.2.0 -> v1.1.2.0
[00015167][17 00][00] v1.1.1.7 -> v1.1.1.7
[00015326][17 01][00] v1.0.2.7 -> v1.0.2.7
[00015429][19 00][00] v255.255.255.254 -> v1.0.8.96
[00015502][01 00][00] v1.30.5036 -> v1.30.5036
[00015576][01 01][00] v1.30.5036 -> v1.30.5036
[00015660][08 00][00] v0.13.0.7 -> v0.13.0.7
[00015756][09 00][00] v3.0.0.10 -> v3.0.0.10
[00015829]Packet upgrade cancelled at version checking.
[00012669]========== 2017.04.04 20:51:41. boot(15) ============
[00012740]Packet [C:\P3X_FW_V01.08.0080.bin] detected, card sn [0x2a05a8e0].
[00012903]Packet upgrade start...
[00012979]Packet checking...
[00013094]Packet vlink 01.08.0080 <-> 01.07.0060.
[00013165]Record vlink 01.08.0080 <-> 01.07.0060 (flow = 0).
[00013250]Done.
[00013338]Version checking[1]...
[00013458][03 05][00] v34.2.0.9 -> v34.2.0.9
[00013578][03 06][00] v2.4.20.22 -> v2.4.14.5
[00013677][04 00][00] v1.44.0.0 -> v1.44.0.0
[00013837][11 00][00] v1.7.15.1 -> v1.7.15.1
[00013986][12 00][00] v1.10.0.0 -> v1.10.0.0
[00014137][12 01][00] v1.10.0.0 -> v1.10.0.0
[00014266][12 02][00] v1.10.0.0 -> v1.10.0.0
[00014406][12 03][00] v1.10.0.0 -> v1.10.0.0
[00014612][15 00][00] v1.1.2.0 -> v1.1.2.0
[00014760][17 00][00] v1.1.1.7 -> v1.1.1.7
[00014940][17 01][00] v1.0.2.7 -> v1.0.2.7
[00015038][19 00][00] v255.255.255.254 -> v1.0.8.96
[00015118][01 00][00] v1.30.5036 -> v1.30.5036
[00015201][01 01][00] v1.30.5036 -> v1.30.5036
[00015307][08 00][00] v0.13.0.7 -> v0.13.0.7
[00015416][09 00][00] v3.0.0.10 -> v3.0.0.10
[00015503]Packet upgrade cancelled at version checking.
Thanks, Bill
thanks, Bill |
