new upgrade
745 11 2017-6-13
hdlou94
Flight distance : 753163 ft
I started doing my upgrade, it has been at least 30-40 minutes and it is stuck at 99.0% what should i do?/ help DJI!!!
2017-6-13
DJI-Jamie
Flight distance : 112405 ft
I'm assuming you're referring to the RC upgrade, correct? Is it still generating the audio queue?
2017-6-13
hdlou94
DJI-Jamie Posted at 2017-6-13 19:37
i have no queue noise, but now i am getting strong magnetic field warnings and i had no choice but to shut it down,,
2017-6-14
jsantacroce
Flight distance : 10036 ft
When mine was stuck at 99% and it said first to pull the data wire and reinsert it I first did that and it was stuck again but then I gave it some thought and I pulled the wire from the copter and plugged it into the controller and the upgrade immediately finished. So I think the message is unclear. Or for whatever reason, that worked for me.
But since I've also been getting STRONG INTERFERENCE Warnings and I have not seen an answer on this yet.
2017-6-14
DJI-Jamie
hdlou94 Posted at 2017-6-14 01:11
Could you happen to clarify what mobile device and Go app version you're running? When you're getting those warnings, do you notice any performance issues or does it seem fine? When you look at the about page, does it now look like both the RC and aircraft are up to date?
2017-6-14
DJI-Jamie
jsantacroce@hvc Posted at 2017-6-14 01:44
I've responded to you on your own thread about this.
2017-6-14
hdlou94
DJI-Jamie Posted at 2017-6-14 09:28
I am using Apple IPad air 2, and dji go app for the p4p
I flew last night hesitantly but did not travel to far as i am still not sure what might happen
2017-6-15
hdlou94
and I'm not sure where to look for the about pages you mention,,
2017-6-15
hdlou94
2017-6-15
I 2 Fly
Flight distance : 8176 ft
South Africa
I had no issue updating both RC and P4P but now I see "STRONG INTERFERENCE"...  I still fly in the same remote are as before (mostly 2.4 as 5.8 has too short a range).  Comments DJI??
2017-6-15
DJI-Jamie
hdlou94 Posted at 2017-6-15 01:11
The About section is in the General settings section when you "Enter the Device". Once you're looking at the camera view, go into General Settings and scroll all the way down then you'll see the About option. All the firmware versions for the main components and the app would be there. Also, try the following button combinations just to make sure that everything is communicating properly:
Reset the RC of presets:
* Turn on the RC, and leave the aircraft off.
* Press C1, C2, and shutter and then turn the it off.
* While still holding the buttons, turn on the RC, then the aircraft and relink the remote.
Manually relinking the RC to the aircraft:
* Turn on both the aircraft and the RC.
* Press C1, C2, and the record button on the RC, which will produce a "D-DD" audio queue. This may take a few seconds of holding them.
* While still holding the buttons, press the wheel on the right side of the RC (ISO). The LED indicator on the RC will turn blue and it will constantly beep "DDDD".
* Use a pen to push in the linking button on the aircraft and hold for 3-5 seconds, then take the pen off the aircraft and wait, it will be linked soon.
In addition, try using the device in airplane mode and try a reset to factory defaults via the Assistant 2 software. Let me know if you notice any changes.
2017-6-15
DJI-Jamie
I 2 Fly Posted at 2017-6-15 01:36
I responded to you on your own thread about this.
2017-6-15
