Gimbal calibration loud buzz &a freezes at 50%
45111 1055 2017-6-13
fans80c231ea
Brand new purchase. I have not been able to fly since purchase first week of March due to my schedule. Free time now so I started the update both drone and controller + batteries. Prior to the update which was done over weekend I had completed gimbal calibration with no issues or buzz sound. All this started after the updates. Anyone else experiencing this? I have tried rebooting several times with breaks in between, repeat gimbal calibration and I get the loud buzz sound and freeze at 50%. Hopefully link below works for clip.
https://www.dropbox.com/s/hya8yg3b35mql4v/Video%20Jun%2013%2C%209%2037%2018%20PM.mov?dl=0
2017-6-13
fans80c231ea
UPDATE: Chatted with DJI support last night and was recommended i reset drone via assistance app on PC, along with controller. Completed reset for both drone and controller. Installed latest firmware and tried to calibrate gimbal, same buzz sound. I will add that i can slightly touch the gimbal with tip of finger and the buzz sound goes away. Almost as if there are parts that are loose causing the vibration/buzz sound. DJI said if issue was still there after resetting drone i would have to send to DJI. My drone has not even seen the daylight outside and I'm having this issue. If anyone has had this issue please share your fix/outcome. I read in prev posts that downgrading firmware might help but i don't think that is a solution for me since it appears to be a gimbal/motor issue. Again, i can touch the gimbal and the buzz sound stops.
2017-6-14
Greg M.
Flight distance : 69442 ft
I had that very same issue after performing the update to A/C and controller. I found out after 3 days of vacation recording.  The video is unacceptable.  Inside the house, I removed props, to find what might set the gimbal to twitch and vibrate, then noticed the noise you described.  I found the underbody of the drone near the gimbal gets quite hot.  Trying to calibrate the gimbal like you, resulted in freeze at 50%.  I downgraded the A/C firmware to a previous version, and all seems well.  Further testing is underway.
2017-6-14
fans80c231ea
Greg M. Posted at 2017-6-14 04:40
Yes same here, the body of the gimbal under drone gets hot when the buzz sound is present.. What firmware did you downgrade to? And did you have to downgrade controller? I'm not even sure if that's possible? I appreciate your input here.
2017-6-14
Greg M.
I don't have that release number handy right now, but it was the previous one installed.  I've only had my A/C for about a month, so it was not updated much.  I left the controller with the latest update, it too has the integral screen built in. P4 Pro +.
2017-6-14
fans80c231ea
I will give that a try tonight before I consider shipping to dji center in CA. I will also try to go back to store I purchased for swap which I doubt that will happen.
So from your experience and downgrade to previous drone firmware it seems this is a firmware issue? I also read the firmware info and it does mention improvements to the gimbal which make me wonder if this is the reason.
I asked DJI is this was a known issue (there are videos online YouTube) with this same issue. Guy who posted the video said DJI replaced his unit.  Picture attached is the firmware with issue if it is related. I will downgrade tonight and report back.
2017-6-14
CP3PO
Flight distance : 10 ft
I got the same buzz after the update as well the unit flies and recordes very well though but
2017-6-14
fans80c231ea
CP3PO Posted at 2017-6-14 06:34
Thank you for your feedback. But what....? Your sentence is cut off.
2017-6-14
Radikaltech
Flight distance : 1385814 ft
I have the same issue, calibration stuck at 50%, loud buzz, horizon tilting in mid flight... Any lights on solving this?
2017-7-19
DJI Thor
Flight distance : 13602 ft
Hi all, this is a known issue about the gimbal noise and our engineers are working on it. And now we would like to release a beta firmware to your DJI account to update for this case. Could you leave me your account address? Sorry for the inconvenience and thank you in advance.
2017-7-19
adrillex27
Hi ! I have the exactly same problem : buzz sound, video trembling, and gimbal calibration freeze at 50%. can I have the beta update please ? my email adress is : adrillex@gmail.com
2017-7-21
FiveDots
I am having the same issue, buzz sound and gimbal calibration freeze at 50%, video is still smooth though.
Has anyone received this beta update yet? Did it help?
2017-7-21
FiveDots
Finally managed to calibrate the gimbal, I took the battery out, recharged it together with the remote to 100%, switched everything on, started calibration and it went through just fine...
2017-7-22
Fly_Safe
Flight distance : 2557566 ft
Switzerland
Hi DJI Thor,
My issues with the new firmware on the P4P Pro are similar
  • During firmware (01.04.0602) upgrade the gimbal start getting noisy
  • Noisy gimbal after firmware upgrade and restarting the copter
  • Gimbal is moving during this noice horizontal (dancing from left to right)
  • Gimbal support get hot
  • Calibration of the Gimbal after Firmware upgrade via App stopped by 50%
  • Downgrade to a other Software is not possible, as it is not available
What did I do so far
  • Deinstallation of the existing Firmware by DJI Assistant 2. Hopefully it was a real de-installation .... I do not think so, because the noise of the gimbal starts directly after restarting the copter
  • Installing the new software via WLAN, 3-4 times, installing was successfully 100%
  • Installing the new software via Assistance 2 via MAC PRO, 3-4 times, installing was successfully 100%
Installed Software
  • Copter firmware: 01.04.0602
  • Controller software: 01.04.01.00
  • Databases of copter and App: 01.00.01.04
  • App: 4.1.3
I am interested to get the beta for testing to oo_anka @ icloud.com
Thanks in advance
2017-7-22
Thatguy32567
Flight distance : 23553 ft
DJI Thor,
I would also like the beta for Phantom 4 pro. I have the same issue. The gimbal makes noise after startup and gets hot. Gimbal calibration fails at 50%. When the drone is turned on and just sitting there, you can hear the noise and the picture on the controller shakes noticeably. When I take videos, you can see the camera shaking from side to side a small amount. and yes I have tried different camera settings and shutter speed and know it is the firmware that is the issue. Please send me the beta! User account is keefe_neise@yahoo.com Thank you!
2017-7-22
Fer09
Flight distance : 362674 ft
Colombia
DJI Thor,
I have the same issue, I would also like the beta for Phantom 4 pro
Please send me the beta! User account is comercial@fernandorincon.com Thank you!
https://www.dropbox.com/sh/flkk0 ... UiwILh9GBuZfQa?dl=0
2017-7-22
Anonymous
Flight distance : 288776 ft
DJI Thor Posted at 2017-7-19 21:31
My email address is
Skladnik89@gmail.com
Looking forward for the beta update. Thanks in advanced.
2017-7-23
Got1Fishing
Flight distance : 112979 ft
I have the EXACT issue going on... this is my first drone and I'm sooo paranoid that it's going to mess up and drop out of the sky. The buzzing  sound stops as soon as I touch it and it gets so hot. Flys fine but I just don't get why it won't calibrate. Debating whether I should return it to Best Buy or if this is something that can be fixed with the beta. Any chance anyone has received it and it fixed the issue? My email is Got1Fishing@gmail.com. Please send my way DJI.
2017-7-23
DJI Thor
Hi all, all the email addresses provided above had pushed the related beta firmware, please log into your DJI account, connect it to your drone and RC and make sure the internet is available to get the release message.
Besides, please kindly click the "Reply" button if you need to reply me so that I can get the reminder and can deal with it asap.
2017-7-23
Fly_Safe
Switzerland
DJI Thor Posted at 2017-7-23 22:23
HI DJI Thor,
thanks for response. I looked in with my DJI Account - which is different to the e-mail account in my thread.
Unfortunately I was not able to find the software in the APP / Assistance 2 (neither for the RC nor for the copter) for downloading. Please check.
Regards
2017-7-24
Fer09
Colombia
Hi thor, thank you very much for your help.
The first thing I did was to reset the AC to the factory settings, then install the previous version Beta (VO1.03.0510), then connect the RC but I do not see any version, anyway I turned on the AC and the RC and the buzz of Gimbal Disappeared completely and finally I could do the Gimbal self-calibration without problem!
But my question is, do not I need the previous version of RC too? Or just reset it?
2017-7-24
Got1Fishing
Hey DJI Thor! i don't believe that I received a notice about the beta? M,aybe I'm looking in the wrong place?
2017-7-24
DJI Thor
Fly_Safe Posted at 2017-7-24 08:38
HI DJI Thor,
Just to verify, is "oo_anka@icloud.com" your account? The beta firmware had been pushed to this account, could you log in this account on the app?
2017-7-24
DJI Thor
Got1Fishing Posted at 2017-7-24 15:11
Hi there, just to verify, did you log in "Got1Fishing@gmail.com" this account to your app and had you connected the app to the internet? If you had still not received it, I'll help to confirm again with our engineers.
2017-7-24
DJI Thor
Fer09 Posted at 2017-7-24 14:04
Thanks for the feedback. If the RC connects stably to the drone, you don't need the previous version of it. So now your drone is back to normal right? If so, should you have any questions, please feel free to contact us, we’d love to help.
2017-7-24
Got1Fishing
DJI Thor Posted at 2017-7-24 21:29
Thanks for the continued support DJI Thor!
I connected my P4P to Assistant 2 yesterday and the beta appeared. I took it out for a flight afterwards and it seemed just fine. The buzzing sound is gone and I was able to calibrate!!!!
2017-7-25
DJI Thor
Got1Fishing Posted at 2017-7-25 02:12
Thank you for the feedback, have a nice time with the drone. Should you have any further questions, please feel free to contact us. We'd glad to help.
2017-7-25
luigislife
Flight distance : 280938 ft
@dji Thor
I'm having the same issue with the calibration can u please email me the beta laautodealer@gmail.com
2017-7-25
mlima
Flight distance : 4559009 ft
DJI Thor,
I am experiencing the same issue as described in the thread.  Can you please push the beta firmware to my account: mlima12@gmail.com ?  Thank you in advance.
2017-7-25
mlima
mlima Posted at 2017-7-25 03:18
DJI Thor,
I am experiencing the same issue as described in the thread.  Can you please push the beta firmware to my account:  ?  Thank you in advance.
DJI Thor,
I have a Phantom 4 Advanced.  My installed software is below:
Aircraft: 01.00.0128
Remote Controller: 02.01.01.00
Flight Database: 01.00.01.04
App Database: 01.00.01.04
DJI Go App: 4.1.3
Thank you!
2017-7-25
fansf1be0477
Flight distance : 1265722 ft
DJI Thor
I am experiencing the same issue as described in this thread.  Can you please push the beta firmware to my account:
medfoch@gmail.com
Phantom 4 PRO
Thank You!
2017-7-25
JonCrapper
Hello DJI Thor
Ive got a similar problem....I cannot control the up/down function of the gimbal with my RC. On startup, the gimbal will shake a little and then stick in the upward position.  Ive tried recalibration of the RC and functions on the copter. I no longer have the option of downgrading my firmware on DJIA2, and have tried reinstalling the current version multiple times. Maybe the beta will help me out...willing to try.
starchild194@yahoo.com
Thanks!
2017-7-25
Fly_Safe
Switzerland
DJI Thor Posted at 2017-7-24 21:25
Hi DJI Thor,
Thanks for clarification - account works - got the the beta.
Installation of the beta was done via Assistance 2.
Gimbal noise disappeared.
Calibration of Gimbal works.
No Gimbal noise after testing of 60 min
Only one point I recognized:
Copter was off and cooled done for IMU calibration to approx. 15°C.
Than I did a IMU Calibration after Firmware update - as shown on the instructions (Gimbal was facing to me).
Figure 1 of IMU-Calibration, the coper has to be tilt over to the left side - Gimbal stays nearly horizontal to the table and the noise starts again.
Then I had to tilt over the copter to the right side - Gimbal was in parallel to the copter. Gimbal gives no noise.
Did this now 3 times with the same result.
Two times with APP 4.1.3, one times with the APP 4.1.4.
Thanks for a working beta and thanks for a comment.
2017-7-25
DJI Thor
Fly_Safe Posted at 2017-7-25 12:05
Hi DJI Thor,
Thanks for the feedback, could you please provide us with a video about the case you mentioned if it is convenience? I would like to also send it to our engineers.
2017-7-25
NECyclone
Flight distance : 12621 ft
DJI Thor Posted at 2017-7-25 20:28
Hi Thor.
   I too am having this problem.  Can you send me the beta version to necyclone@gmail.com
Thank you for your assistance
2017-7-25
DJI Thor
NECyclone Posted at 2017-7-25 21:05
Hi Thor.
Just to verify, are you using Phantom 4 Pro or Phantom 4 Adv? It has different beta FW.
2017-7-25
Fly_Safe
Switzerland
Hi DJI Thor
Attached you find the link from the dropbox.
https://www.dropbox.com/s/qjpoxf ... 04P4%20IMU.mp4?dl=0
The movie will be removed automatically after 7 days from the dropbox.
Thanks for some comments.
2017-7-26
JonCrapper
JonCrapper Posted at 2017-7-25 11:03
Hello DJI Thor
ps Phantom 4 pro
2017-7-26
Ryan K
I am having this issue as well and have not been able to fly since the last update.  May I be added to the list as well?  rpk2012@gmail.com  Phantom 4 Pro.
2017-7-26
NECyclone
DJI Thor Posted at 2017-7-25 21:21
Phantom 4 Pro
Thanks Thor
2017-7-27
