djiuser_syWjOZN
Flight distance : 2382 ft
kg11 Posted at 2017-7-21 20:47
Ok
Just tried a few things I have a mavic with DJI googles it works a treat. A stunning sensation flying this machine with these googles and then being able to lift them out of the way and view the screen and view the drone with line of site
just tried a bunch of things with my inspire 2 and 5.5 inch crystal sky and the googles most are expected some not. Hooked the drone to my control and the crystal sky fires up straight away. I then plugged the googles into the Hdmi port on the rear of the remote and so now you have the crystal sky working and an output picture to the googles. Then I removed the HDMI cable from the rear of the remote and plugged into the HDMI port on the crystal sky, once again the crystal sky continues to work as the main monitor and the googles now have again a picture, not only a view off what the camera sees but a view of what is on the crystal sky
Hi kg11,
I have a similar setup but instead of the Crystal Sky display, I'm using an iPad Mini via USB to the RC. I tried the same steps you did, but can't get any control via the DJI Goggles. I.e.:
1) Connect DJI Goggles to HDMI on the RC (Live View only - see what the X5S sees, but no control)
2) Disconnect the iPad Mini from the USB and disconnect the DJI Goggles from the HDMI
3) Connect DJI Goggles to the USB on the RC (according to the 2017.04 manual, this should allow Head Tracking, see below))
4) Wait for a bit (sometimes have to hit the "Back Button") and then I can see the control screen on the DJI Goggles, but I can't control anything with the DJI Goggles (beyond the focus via the C1 or "Fn" button) as described in the 2017.05 manual.
Sadly, it looks like DJI made a mistake on the extent of compatibility between DJI Goggles and Inspire 2 - they changed the text from the 2017.04 manual to the 2017.05 manual:
DJI Goggles User Manual, v1.0 2017.04, page 11 text:
"For Inspire 2 aircraft, head tracking is also supported but only if the Goggles are connected with the
remote controller via USB."
DJI Goggles User Manual, v1.0 2017.05, page 11 footnote:
"For the Inspire 2, if the Goggles are connected with the remote controller via the USB cable, only live view and somatic control of the focus is supported."
I bought DJI Goggles after reading 2017.04.
kg11, if you could please provide a step-by-step sequence of what you're doing to get head tracking to work, along with the firmware versions you're running on the Inspire 2, RC, and DJI Goggles, I'd appricate it! If I can't get it to work, I think I'll return them because I want a gimble head tracking solution fed via my slave RC while flying on my master RC.
Will |
