RicardoGray
Flight distance : 4356421 ft
cbeard93 Posted at 2017-6-14 11:56
Thank you! I feel pretty confident about it. I
m just worried that when I change the motor, it's going to end up being the whole board that is fried and not just the motor. I really hate that DJI made these things so hard to work on. Especially considering what they cost, you should at least be able to easily do repairs.
I know what you mean! I had chatted with support and all they would say was it was probably the main board and to send it in. I had just flown the night before and couldn't imagine the board was bad, so I made the decision to buy the motors and after I finally got the motor hooked up, it came to life and I was very pleased I didn't have to spend another $200 on a board. I did find out that your can test these motors somewhat with an ohm meter. On mine it felt rough like I said to turn, so that was convincing enough for me and that is why I continued to keep trying to figure it out. These are 3-phase motors, so you should have continuity between any, and all of the leads. Nothing should go to ground to the case of the motors and all three wires should "ring-out" to the others, if you know what I mean. If any combination of 2-wires don't have continuity, there is a problem with it. That is how I found my problem. Not to repeat, but after I sliced the new motor in, and I still had the error, I decided to check the others and also check them right at the board. I had checked my new motor before I put it in the phantom, but when it wouldn't fire up, I check it at the soldered connection on the main board and it was open between to legs........I knew that wasn't right and after looking closer, one of my wire was broken in two inside of the insulation, I could feel it. The original motor was bad though anyway, and I wondered if the bearings were going out causing a bigger load on the wires and they finally burned into. Just guessing here. Anyway, sorry to bore you with my story again, but thought it was worth sharing how you might check your motors. I found this helpful. |
