fans7f0f5fc1
Flight distance : 1212224 ft
13MStang Posted at 2017-6-14 10:28
same thing happened to me. I was able to insert the card into my goggles and see any video that was recorded while the goggles were connected. But this was after i tried to view videos i had recorded without the goggles. when i inserted the card with videos recorded without the goggles, i got the same File List empty message.
I think I may have found the answer: The Micro SD Card slot on the DJI Goggles is used to download files from the aircraft to the goggle’s onboard SD card for backup and to view captured video files.(Only videos with a resolution of 1080P/60fps or lower can be viewed via the Goggles.)
I recorded my videos at 4k. I will try the lower resolution later to find out for sure if this is the problem |
