Crabbing
1256 2 2017-6-14
wvshooter316
After calibrating the compass and IMU of the M600, I am having issues with the drone crabbing instead of following a straight line. I have been noticing this issue in free flight and while using UgCS for flight planning. What could be the problem.
2017-6-14
DJI-Jamie
Flight distance : 112405 ft
What else are you using as a payload? Do you notice the same behavior when using the Go app?
2017-6-15
wvshooter316
We have a mobile LiDAR unit that weighs approximately 8-10 pounds mounted underneath of the M600. Regardless of using the DJI GO app or third party apps, the drone looks like it crabs, even in manual flight.
We had an incident where the drone flipped on its top after attempting to land in a grassy field and the motors spun on the grass for approximately four seconds. This only resulted in one busted propeller. After replacing the propeller and performing  a test flight, the drone performed as expected.
The DJI GO App does not show any errors for motor ESC's, IMU, GPS, etc. Is there any way to determine performance issues with the drone without performing test flights?
2017-6-19
