AirPhoto1.com
Flight distance : 455558 ft
AirPhoto1.com Posted at 2017-6-19 19:30
You're correct of course, I just purchased an iPad 4 mini, hoping that I'd have an easier time seeing the text and icons on the larger screen, and that the non-reflective coating on the iPad mini 4 would also make it easier to see in bright sunlight - which was definitely a problem when trying to fly yesterday. Thanks for the info.
I forgot to add, that it did fit very nicely. Key, is tucking the first corner of the iPad 4 mini into the cutout in one arm of the controller, before slipping the 2nd corner of the iPad into the 2nd arm. If you try to force both corners in at once, it will likely stress the arms - and it's not necessary to do that. |
