DJI GO App 4 Settings Reset (Firmware Upgrade)
1733 2 2017-6-16
cristianc
Flight distance : 1008143 ft
Hey guys,
Don't want to scare you however if it is possibile can I get you guys to check to see whether "calibrate map coordinates (for china mainland)"  is checked? Only for those that do not reside in China and have upgraded to latest firmware.
For some reason mine was on even tho I am in Australia and had to uncheck it...I am thinking maybe I switched it on by mistake as opposed to firmware upgrade messing with my settings.
Cheers
Cristian
2017-6-16
hungdang
Flight distance : 4931706 ft
After you update your app and firmware you should check and correct everything. DJI reset lot of thing when you update
2017-6-16
cristianc
hungdang Posted at 2017-6-16 08:44
I agree, by the looks of it lucky I checked otherwise  I would have been in trouble
2017-6-18
