Dangair
As silly as this sounds, you may wis to try suspending your model with the props off. First though, go through your pre start procedure, then start up on the ground so that the aircraft sees the ground as it should. Hit the throttle and of course the copter won't fly but at that point hang it from something two meters off the ground and raise the landing gear. Function the motors and see if all works as it should. If no, then the firmware may have issues. If yes, move on to a fresh copy of the app. Re do from the beginning this time with app installed and running. If the aircraft still operates as it should but the camera is not showing a picture mess with the map view area and toy with other settings. If you still get no image, assuming you see the hud, heads up display, which by the way can be dragged of the view, it is possible to deduce the gimbal may not be function correctly, due to a bad camera or a bad physical connection. |
