DJI SPARK UNBOXING & HIDDEN FEATURE FOUND to increase range and r...
12Next >
36272 56 2017-6-17
eL6uRCU98KkD
DJI SPARK UNBOXING & HIDDEN FEATURE FOUND to increase range and reliability!
This can increase the range of your drone because the phone wifi won't interfere with the drone
Watch this video for the fly more combo unboxing:
Watch this video for for the hidden feature of the DJI Spark:
2017-6-17
fans968d8ec6
Flight distance : 150899 ft
Tried it with my OTG adapter and my Nexus 6p. Amazing!!!... All the WIFI problems reported were gone.
2017-6-17
Nic
Flight distance : 604242 ft
South Africa
I'm afraid that wasn't a hidden feature there is a reason the remote has antennas
When you use the remote it makes use of dji's occusync system which is a pretty phenomenal "wifi" system. It can happily stream HD footage 6-7km on the mavic which leaves me wondering why I can barely get my household wifi web browsing across the house!
You'll also be able to utilise sports mode with the remote which is disabled when flying off your phones wifi.
Hope you are enjoying the spark and thanks for the unboxing. Happy flying!
2017-6-17
aviscomi
Nic Posted at 2017-6-17 12:35
Hmm...I don't believe that the Spark utilizes the occusync technology
2017-6-17
neo2ooo
Flight distance : 87372 ft
Can anyone confirm this works on IOS? I am having terrible connection issues to the RC from the phone.
2017-6-17
R&L Aerial
Flight distance : 298100 ft
That little short lightning to micro USB cable that comes with the mavic works with the spark and iPhone 6s plus. It gives you a not supported device message but it still works, you have to hold controller and iPhone because the cables way to short but it works great! Just ordered myself a lightning to micro USB cable from b& h
2017-6-17
R&L Aerial
neo2ooo Posted at 2017-6-17 12:46
Yes it does, I just tried it with the short mavic cable but unless you've got a mavic or a lightning to micro USB cable your SOL till you get one
2017-6-17
Bradders
Flight distance : 862283 ft
This is a great idea, this is what I have got http://amzn.to/2sFhJUk
2017-6-17
R&L Aerial
If anyone has the apple camera kit connector try it a report back, I've read were it might only work from 10. 2 down?
2017-6-17
R&L Aerial
It makes perfect sense that this works if the goggles are going to be compatible with the spark?? I wonder if a micro USB to Hdmi adapter might work too??
2017-6-17
dronist
Austria
You need to read the forum before posting about HIDDEN FEATURES.
2017-6-17
neo2ooo
So I went to Best Buy and bought a insignia micro USB to USB adapter and used that and I'm happy to say it works great. I also have the latest iOS firmware. The only thing is with that method you don't get a wifi strength signal in dji app. Can someone confirm that please?
2017-6-17
mtnstream
Flight distance : 222621 ft
If I recall correctly, "Hidden Feature" was verified a few days ago.  Regardless, good news RC USB does transmit dataand is not just a WIFI connection.
2017-6-17
hallmark007
Flight distance : 9827923 ft
Using the same can't get connected iPhone 7.
2017-6-17
FFS
Flight distance : 50003 ft
I can confirm that the connection is horrendous when connected to the RC. But if it is the connection between the RC and the phone as opposed to the connection between the RC and the Spark, it's kind of odd that the Spark goes into "signal lost" mode any time that the phone connection breaks up with the RC.
2017-6-17
Nic
South Africa
Oh wow. I see I was mistaken in thinking the default was a USB connection from the flight remote to a phone. Seems silly to be creating an additional network when the mavic and phantom had successfully operated via USB.
2017-6-18
fans968d8ec6
FFS Posted at 2017-6-17 20:44
After doing some research I have been using RC with my Nexus 6P by first setting it Airplane Mode and  using the 5.8 Mhz band.  So far so good, no more video lags, aborted transfers, unresponsive controls...
Nevertheless, I will carry the OTG cable on the event of issues.
2017-6-18
MAVICDLNM
Flight distance : 10696686 ft
fans968d8ec6 Posted at 2017-6-18 14:53
heard that the interfere was caused by bluetooth in phone.  Not sure that is the only cause.
2017-6-18
fans968d8ec6
MAVICDLNM Posted at 2017-6-18 23:58
Let me try that tonight... I'll report back.
Thanks!
2017-6-19
Thor1
Flight distance : 196837 ft
Nic Posted at 2017-6-18 01:33
I agree, DJI should definitely make this an option!
2017-6-19
FFS
Can't get this to work using the little mavic cable and an iPhone 7 on the latest firmware. Did DJI already patch it out?
2017-6-19
SpicyLobster
Flight distance : 282979 ft
I tried on my iphone 6 with a micro to lightning cable and it appears it is only charging the RC battery but will not connect the video source... very disappointing
2017-6-19
dari_017
Flight distance : 6016004 ft
SpicyLobster Posted at 2017-6-19 13:58
Hello were you able to connect again using the micro usb to phone method ? I got my spark today and also bought a micro usb to type c cable to connect my phone ( Nexus 6P ) but like you said it is only charging it , i can't get video feed. I tried turning on the remote and then connecting the micro usb to no avail.
2017-6-21
fansd1d3fe67
I'm using an old, generic USB 2.0 OTG cable to connect my iPhone 7 (iOS 10.3.2) and it works perfectly. You have to make sure everything is turned on BEFORE plugging into your iPhone. So:
Make sure your Spark, RC, iPhone, and DJI Go 4 app are all updated to the latest versions. (If you need to update any of them, reboot the device after updating it)-Put iPhone into airplane mode for best results. (re-enable wifi if you prefer, but leave blutooth off.)
-Power up Spark
-Power up RC
-Open DJI Go 4 app
-Connect RC-iPhone, dismiss the "This device may not function properly" message.
-Fly.
Edit- Add step to put iPhone into airplane mode for best results.
2017-6-21
SpicyLobster
dari_017 Posted at 2017-6-21 15:21
I was able to get a USB to micro converter that did the trick with a normal cable.. its at
https://www.amazon.com/gp/produc ... 0_s00?ie=UTF8&psc=1
Also dont use the white cable with this converter it appear to only be a charge plug. I will double check that tonight.
2017-6-22
Bradders
This works perfectly and drastically improves the signal quality of the FPV Feed, I have no Idea why DJI did not show this as a feature, it should be an option, connect to the controller via WiFi or Wired, I tried both and wired is much more reliable. I have one of these coming http://amzn.to/2sZFab1 and also ordered this http://amzn.to/2sZFg2n so can plug the iPhone cable straight into the controller!
2017-6-22
dari_017
SpicyLobster Posted at 2017-6-22 13:34
Awesome thanks for that I just ordered one and returned the micro USB to USB type c , I also tried the one that came with my Mavic and it worked , not a big fan of so many wifi signals  working at the same time , plus I think the adapter will give you a better video feed quality, thank you again .
2017-6-22
SpicyLobster
dari_017 Posted at 2017-6-22 16:54
glad to help. it took a decent amount of trying to find the right thing. I have another cable coming that works for them he mavis micro side plug  so it should work for the spark.
2017-6-22
dari_017
SpicyLobster Posted at 2017-6-22 22:18
Got the adapter today, and it works perfect ! Thank you.
2017-6-23
Bradders
I got my cable come yesterday, this is a perfect way to improve the FPV feed, this is what you need:
http://amzn.to/2tEY2Jx
OR
http://amzn.to/2s6vS8p
2017-6-23
NewtonLeWilows
aviscomi Posted at 2017-6-17 12:44
You are correct
2017-6-24
marcloig
nice post!
when u use this adapter
https://www.amazon.co.uk/gp/prod ... def345352dbd7ea666e
the phone or iPad or whatever fits properly in RC??
This is very important to know. Thanks!
2017-6-24
Jestered
Flight distance : 16112 ft
Hi all,
So I got the correct cable and adapter for my iPhone 7.  It connects to the RC and device just fine.  The problem is that I can't fly more than 100 ft. away.  Once I reach 100 ft. the RC informs me that I've reached the distance limit.  I checked the altitude limit and it's set at 120 meters, which is 400 ft. so why is it telling me I can't fly farther than that?  If I disconnect the cable and adapter, and fly it again with a wifi connection to the RC, I get normal flight again and can go beyond 100 ft..  Anyone know why this is happening?
2017-6-24
paskalicky 4
Flight distance : 260981 ft
fansd1d3fe67 Posted at 2017-6-21 20:21
-Power up Spark
I have a iPhone 7+ Hope I can get same results?! Which "generic USB 2.0 OTG" cable do you have? OTG cable for iOS ? I am clueless. Is that a Lightning to micro USB? Does your hook up use lightning to micro USB adapter and cable? HaHa So many questions ! Thanx just wanna fly
2017-6-24
Tviscomi
Flight distance : 106886 ft
2 for $7
https://www.amazon.com/dp/B00N9S ... dp_T2_b5TtzbJ78N95P
2017-6-24
paskalicky 4
paskalicky 4 Posted at 2017-6-24 13:44
Duh .... OTG "FROM" RC.
RC --->Micro -->OTG -->USB -->Lightning
Right? ..... OMG
2017-6-24
fanse3ef7808
Flight distance : 115741 ft
neo2ooo Posted at 2017-6-17 14:35
I confirm that I also do not get the wifi signal strength in the DJI app when using the OTG cable and an iPhone.
Is this the case for everyone?
Is there any way to know when you are about to lose the connection with he Spark?
2017-6-24
pvtsailor
Flight distance : 675709 ft
This guy says that it does not work with ios
2017-6-25
Lorador
Banned
China
2017-6-25
hallmark007
Lorador Posted at 2017-6-25 07:40
Hi have you test the goggles? Can goggles be used with Spark? http://forum.dji.com/thread-101777-1-1.html
Same post to many times CLICK BAIT. POSTS SHOULD BE DELETED........
2017-6-25
12Next >
