MavicBeginner
Flight distance : 25052 ft
Malaysia
DJI-Jamie Posted at 2017-6-17 22:17
Based on what's provided, there may be some internal issues with the aircraft or damage to the gimbal's ribbon cable that would require for you to send the unit in for service. Have you gotten in contact with Support about this?
Thanks for the prompt response. I've reached out to Support but they're only available during office hours. I saw on some forums that it may be the ribbon however there's no obvious damage to any of the ribbons. Here's my message to DJI Support:
Hi DJI,
Yesterday i tried my new Mavic in my house and it suddenly just drifted off and hit the wall without me touching the remote (i assumed the obstacle avoidance feature would protect me from this?).
Then I went outside and tried again, the drone was stable and hanging at around 30M suddenly it veered to the right and crashed into a wall (??) about 10M away.
Now when I start the Mavic, i get a message "Gimbal Gyroscope Error". The Gimbal does its usual flips and rotations but leaves the camera pointing to the right instead of the centre.
The Mavic flies without issues, video feed is fine and autofocus and zoom are fine.
However i cannot tilt the Gimbal and it's shaky.
I checked the ribbons and wires, rubber bands and gimbal plate, all seem OK and in the right position (the plate had jumped over one of the brackets but i pushed it back under it).
When i now try to Calibrate the Gimbal in DJI Go 4 app. it starts with a green banner saying "Gimbal Calibrating" then it disappears and never comes back.
When I try to Calibrate using Assistant 2 it stops at 71% and says "Calculation Error: Check the Screensize"
I don't know what to enter in the Screensize box (unit: inch), I've tried everything from 9 - 13.5 Inches and they all stop at 71% withthe same message.
do you have any idea how to fix this problem?
thanks |
