RichJ53
Flight distance : 1837356 ft
Cougar1 Posted at 2017-6-19 03:28
Hi Rich, no I did not Loctite the screw, only lighted it up a bit, so it staid in the correct position. If the legs where tight, the only way I could see they where out of alignment, would have to be either wrong setup from DJI or if it had been bumped during transport. Know you are just as anal as me in maintaining your equipment.
Mine was simply a bit loose and as all serious flyers would know, it is part of maintenance to check everything prior to flight. These awesome machines are put together by humans, and things can happen during transport where boxes are tossed around.
Thanks cougar
I find it strange that these screws do not have some means of vibration resistance measures/ maybe I am overthinking this, but on these types of parts usually have a lock or Loctite so they do not move during use.
Rich |
