Have a phantom 3 standard and have failed many times to upload the recent firmware to the drone. I have ensured there is no data on the sd card and on the tell phone.
When I start the drone upi get the message no image transmission
Can't get my firmware update either. Transfer bin. File to micro sd, put in bird, the bird does start up dance then deadly silence, no bleeps green light on gimbal on permantly, red lights on front on rear yellow flashing. Tried on three occasions today left it in the above state for 30 min 50 min and 25 mins. Took micro sd out and bin file is there but no txt file . Fed up any advice
I have the same problem I can not update my phantom 3 standard, this is the result
========== 2014.01.01 00:00:14 remo-con disconnect======
Packet: P3C_FW_V01.07.0800.bin
Result: Failed.
Reboot the aircraft and try to upgrade the firmware again.
========== 2014.01.01 00:00:15 remo-con disconnect======
Result: Failed.
Someone can help me
armando208 Posted at 2017-6-22 01:17
Yeah I'm having the same problem, I've even tried doing a force update by holding the link button down and after a few minutes it still fails
Having plenty of data on my phone..I just got the new update... connected my phone to phantom wifi with remote on... and my drone on... hit the update button... (said it could take up to 30 min).. my drone made noises the whole time... completed ..turned off then back on.. went and flew around
I had more trouble posting this than updating... hehehe... with data on phone... i turned on remote.. connected to phantom on wifi.. turned drone on without blades... seen update was ready to start.. hit update.. drone made noises whole time it was updating.. when complete.. turned off then back on... went and flew
fansee053147 Posted at 2017-6-23 20:29
I can use my samsung or the iphone.. on the dji go app
Today i´ll have a look to the new FW and i´ll write down each step i do for upgrade and post that here if anybody needs. ....and make for sure you have a cooling device for the copter during upgrade.
