DJI Diana
Flight distance : 2408 ft
Dji Randhawa Posted at 2017-6-25 05:54
So spark is also not gaining altitude while flying backward in dronie mode. Also in helix mode it drifts away from subject. Rocket and circle seems to work fine. I am going back and forth with dji support ( chat ) and they first told me to reinstall the app (dji go 4) on my note 4 and refresh the firmware (v01.00.0400) . So i did that and tried Dronie again. But it still didnt work. Again had a chat session with dji support. This time they told e to do compass calibration and IMU calibration and then again refresh the Firmware (v01.00.0400) and reinstall the app. So i did all that but still spark is not gaining altitude in Dronie. I have no idea what to do about that.
So sorry to hear about the issue you are faced with, please ensure the drone is flying more than 2 meters above the ground, then try the dronie mode again , see if it works. If it is still the same, please export the black box data for analysis, thank you in adavance.
To export the data, please download the Assistant 2 from DJI offcial Spark webiste, install it then connect your Spark to PC, run Assistant 2, click on "Black box" in the left side, you could save it to local. |
