hallmark007
Flight distance : 9827923 ft
It's not confusing, you don't need to calibrate your compass every flight, in fact you never need to calibrate your compass , unless you are prompted to, and it clearly tells you this in your manual.
This calibrate your compass is a myth, it came out of manuals printed for much earlier models and mostly because of misleading English in the way they were written. You also don't need to calibrate you compass if you travel distance not 50 miles not 100 miles not 1000 miles, all of this is a myth stick with what is says in your manual and instructions you receive from your app and you will be fine. |
